best paint for machine restoration?
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
    Feb 2009
    San Diego, CA
    288
    Default best paint for machine restoration?
    I'm looking for a good paint for my old rockford lathe restoration. I want it to hold up to oil, trim-sol coolant, ect...
    I'm assuming a 2 part paint is best, right?
    Any brand/models would be greatly appreciated. If i can get it through somewhere local, that'd be great.
    Thanks in advance!
    Dan
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,718
    1316
    2157
    May 2002
    South Central PA
    12,504
    1552
    2671
    Here's My favorite, Ace Hardware Rust Stop Enamel on a gear shaper after 10 years of steel chips and chlorinated cutting oils. It's even better if you put a hardner in it, and they will custom mix colors for you.
    Jul 2004
    Houston, TX USA
    27,206
    Here is a guy that knows how to paint. Notice this is a brush job.
    Hendey 14 by 6 Tie-Bar Rehab
    John Oder
    Aug 2005
    Tacoma Washington
    1,332
    81
    122
    I use a quick drying oil base enamil. Brushes on real nice, and leaves a good finnish.
    Nov 2008
    manitoba
    46
    get thyself down to the local auto body paint supplier.he will mix the exact color that you want and also in any of several formulations (enamel,clear coat-base coat) and will also supply proper primers etc.also look for some of the two part paints...extremely tough. stay away from some of the exotics though,you may find them quite toxic.reat place for advice.ps this can be quite expensive but will last a long long time.I do all my old equipment like this now and stay away from tremclad type products.my .02 worth
    Jun 2006
    Beaverton, OR
    5,459
    51
    Be careful, those auto ones can be very toxic.
    I used Sherwin William's Alkyd Enamel Equipment paint. Holds up well against coolant and oil. Make sure you use a hardener though or it will take about 2 years to fully cure. (No joke, 2 years, really)
    Oct 2006
    Klamath Falls, Oregon
    3,467
    355
    864
    I vote for Blue Porch Paint!
    May 2002
    South Central PA
    12,504
    1552
    2671
    Quote Originally Posted by macona View Post
    He's right, I tried some and it took a month until I could handle it without leaving fingerprints in it.
    Feb 2009
    San Diego, CA
    288
    Quote Originally Posted by Perry Harrington View Post
    somehow i knew this was going to pop up.
    thanks for all the advice guys. it's been hell stripping this thing, but it's almost done. i cant wait until i can start putting it together!
  11. #11
    Oct 2005
    CANADA
    Ontario
    663
    81
    196
    If you want to go to the extra trouble a 2 part polyurethane over epoxy primer can't be beat IMHO. I used Endura on my 8520 and it came out great:
    http://gallery.intlwaters.com/thumbnails.php?album=323
    Here's their site:
    http://www.endura.ca/
    Once this stuff is hardened nothing (including battery acid) will touch it.
    As suggested though the two parts are quite toxic and you should really have a proper place to spray it if you go that route. Pretty sure they have formulas that brush well too.
  12. #12
    Jan 2009
    Central Florida
    492
    DuPont Imron is insanely tough. Normal application: Aircraft paint. It withstands several hundred hours immersion in heated Skydrol (aviation hydraulic fluid) with only a minor loss of surface gloss and hardness.
    CJ
  13. #13
    Jul 2004
    central NC
    2,365
    16
    519
    Imron is also insanely hazardous and isn't the paint to be used by a rookie without proper respiration equipment.
    Vote for Duron Alkyd Enamel.
    Steve.
  14. #14
    Jan 2002
    8,718
    1316
    2157
    Well, I guess paint for machines is like Pizza....everybody has their own idea of what's best....
  15. #15
    Oct 2005
    CANADA
    Ontario
    663
    81
    196
    Quote Originally Posted by cmjohnson View Post
    CJ
    Yup, the Endura I mentioned is similar to Imron, but about 1/2 the price. Don't think it's too much to worry about if it's brushed, ventilation is your friend of course...
  16. #16
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,099
    429
    I am just finishing up a paint job on my band saw. I used a "single stage" epoxy with hardener and I am not too happy with the way this paint works. I would have used acrylic enamel with hardener or Imron had I known the piss poor coverage. I bough this stuff because the maker claims it flows out using a brush or roller. After three trys with a brush and roller I color sanded it and shot a tack coat let it sit and sprayed a wet coat. It still needs more paint to cover some areas.
    I wanted to avoid spraying the saw so I sought out a paint that was brushable, I don't know what the standards are for brushed finish but it was well below my standards. After using this I would hearly recomend skipping the "friendly" paints and go directly to an auto paint supply and buy something I know works.
    Steve
  17. #17
    Dec 2006
    Buffalo, NY
    276
    Plain old Valspar Tractor and Implement (I think it's an oil based enamel) paint applied with a brush will give good results if you prep the part to be painted well enough.
    Lathe update with some pics
    Ryan
  18. Likes BobRenz liked this post
  19. #18
    Feb 2009
    San Diego, CA
    288
    Quote Originally Posted by SteveF View Post
    Steve.
    Any more hazardous than most auto paints?
    I have all the neccesary painting equipment needed to spray, and i've sprayed a few cars in my past, but i'm still on the fence there. I think i might brush it on to get a thicker coat, and to be a little lighter on the mess. I guess it all depends on how good my body filler job comes out.
  20. #19
    Jan 2009
    Brighton MI
    I just painted my 1964 Bridgeport with PPG Deltron base coat/clear coat. I power sanded most of the machine base as it was in great condition having been properly reconditioned in the early 1990's. The head was from an older machine and had been poorly painted about 6 times. I stripped the head with chemical stripper to bare metal and used the same heavy (catalyzed) primer I use on car restorations. Lots of sanding and then the final catalyzed auto paint on top. A pint of color was $57. I probably spent $100 with the clear and catalysis but it looks as good as my custom sports car! Catalyzed car paints are good with mild solvents and can be touched up if necessary. No, I didn't buff it out.
  21. Likes gwilson liked this post
  22. #20
    Feb 2009
    San Diego, CA
    288
    Quote Originally Posted by Sportech View Post
    Looks great! That's funny, my friend commented that i should paint it to match my mustang, which is the same deltron base and clear (but black) with a House of Kolors Red Apple Kandy from the body line up. I thought about just going to pick up a quart or 2 of basic single stage auto paint.
