Hoping someone here has some experience with porous graphite. I've seen lots of posts about people trying to make their own air bearings using porous graphite, but nothing about maintaining or cleaning them, so here goes:
I've been using a set of porous graphite air bearings sourced with CO2 (using bottles and a regulator from paintball parts)to build a fully self-contained floating platform to be used for satellite propulsion testing and attitude control testing. Using CO2 has not been a problem and the platform has worked very well for this purpose.
The other week, I was checking the platform for leaks by spraying soap water around the fittings and checking for bubbles--while the system was turned on. I failed to remember that the CO2 bottles have an anti-siphon tube in them to prevent liquid CO2 from entering the rest of the system, and the regulator began to freeze up and the whole system stopped working.
I was able to replace all the damage components in the regulator and it works good as new now, but the air bearings are acting as if they're "clogged". Prior to this, I was able to run the whole thing at about 30 PSI, but now I have to crank it up to 60 PSI and it still doesn't float as effortlessly as it used to. I'm trying to figure out what could have caused this but I don't know enough about how porous carbon interacts with soap, water, or liquid CO2.
I would imagine that any liquid CO2 would boil off quickly and escape as a gas. And if soap were to somehow bind to the microporous structure of the graphite, wouldn't a quick dunk in water wash it away? I've tested the bearings to confirm them still work by submerging them in a bucket of tap water and observing bubbles emerge from them, and I've rinsed them with isopropyl alcohol to displace the water, but they're still acting funky.
If anyone here has some experience with this, I would greatly appreciate any suggestions you have.
