best steel for fireplace grate?
Results 1 to 18 of 18
    Nov 2007
    ohio
    622
    32
    17
    Default best steel for fireplace grate?
    i was hoping to use stainless for my outdoor fireplace grate because it would pretty much last forever. however, i put a 1/2" 303 stainless rod in the fire just to see how it handled the heat. it warped.
    is there a stainless that won't warp with fireplace heat? if there are no options, should i just go with cold rolled? i'd really rather not use regular steel because it would rust and stain the bricks.
    thanks
    caspian
    Aug 2004
    Virginia
    1,965
    147
    664
    Is there any possibility of getting an old sewer grate at the junk yard or something. In my opinion nothing beats cast iron for this application.
  3. Likes S_W_Bausch, TDegenhart, Joe Miranda liked this post
    Jan 2005
    CANADA
    Saskatchewan
    9,543
    1163
    3251
    Yes, cast iron is great for grates
    Stainless is bad for warping because of its low thermal conductivity. This means the side facing the fire gets a lot longer than the cold side, and that upsets the metal permanently.
    I had an idea: you can buy solid cast iron rods for brazing. They are typically cast in kind of a rough square cross section, maybe 1/4" square. I wonder if you could construct a custom grate from those? You'd need to use a bit of nickle rod to weld them.
    Try to design a grate that is constrained on only one end. For example, weld all the bars of the grate at one end only, and allow the other end to be supported by a 'rest' which allows the bar to expand and contract as needed.
    Dec 2004
    uk
    12,498
    3495
    5613
    Cast iron is the only thing that will hold up. It makes stainless look silly in this application. Old drain grates are some of the best.
    Feb 2009
    Tucson, AZ
    630
    12
    23
    A friend of mine used a couple of short (2') pieces of railroad track in his fireplace. But then, he has a fairly large fireplace
    Nov 2007
    ohio
    622
    32
    17
    Mine is 52" wide, so size isn't a problem. I like the railroad rail idea. Any ideas on where to begin when calling around?
    Mar 2006
    Cape Cod, Massachusetts
    4,829
    1133
    1877
    Maybe I misunderstood the OP, but I thought you wanted a grate to put on top to hold food, or pots and pans? Rail track would be great for the bottom for a log rest.
  9. #8
    Dec 2008
    Vt USA
    6,008
    531
    1840
    re-bar works.
    Cheers
  10. #9
    Nov 2007
    ohio
    622
    32
    17
    Poor communication on my part. This is for the logs. I'm "testing" rebar now and it seems to hold up without warp. It doesn't meet my anti rust criteria, but would be a nice runner up if I can't find railroad rail. I really like the industrial look of railroad rail.
    CalG, you posted that when I was typing mine. Rebar will be the next option.
  11. #10
    Jul 2011
    Brusly, LA
    620
    19
    249
    Quote Originally Posted by CalG View Post
    re-bar works.
    Cheers
    Yep, best material out there for this. I have been slowly replacing the warped/rusted out parts of my grate with 3/4 rebar as they burn out. Eventually Ill have a solid rebar grate. Its something how you can see the difference between the commercial grate rods that came with my fireplace and the rebar.
  12. #11
    Nov 2004
    Birmingham, AL
    13,049
    6156
    2432
    Inconel.... if money is no object, lol.
  13. Likes jdj liked this post
  14. #12
    Feb 2009
    Tucson, AZ
    630
    12
    23
    Caspian: I have no idea where my friend got his track. But we have a big Union Pacific yard here in Tucson, and I'm guessing that might have had something to do with it.
    If you have a terminal/switch yard near you, that's where I would start calling.
  15. #13
    Sep 2005
    il.
    6,558
    29
    1175
    crane builders use alot of 30lb rail
    easier to handle and shorts may be had
  16. #14
    Apr 2009
    Ontario Canada
    608
    378
    324
    Cast Iron is the grate of choice however rr track would work well and once hot would hold heat for an extended period of time. The secret of grates that last is don't let the ashes build up under the grate, they will hold the heat in like a forge and burn up the steel.
  17. #15
    Dec 2011
    Charleston/NYC
    1,286
    1665
    562
    if you wanna take a trip to Charleston ive got a huge pile of #138 track that you can scavenge for free.
  18. #16
    Jan 2007
    1,219
    273
    405
    Quote Originally Posted by Mike C. View Post
    You laugh...I'm designing a set of andirions now from Monel 405 1" hex bar...
  19. #17
    Dec 2004
    uk
    12,498
    3495
    5613
    Quote Originally Posted by tailstock View Post
    That's the secret with iron, anything a std gas cutting torch won't burn or melt well will make a good grate. Rail road track just buys time over smaller sections being so large.
  20. #18
    Jan 2012
    Urbana, ohio
    30
    If it's just a grate for burning logs, rust shouldn't be an issue anyways. Weld up some large diameter rebar. It will outlast us all.
