Best thread inserts for delrin?
Results 1 to 14 of 14
    Apr 2009
    OHIO USA
    38
    Default Best thread inserts for delrin?
    I am making a few parts out of delrin and need a few blind tapped holes. I was thinking of using helicoils but was wondering if anyone has any experience with the press in style inserts. McMaster-Carr I am mainly concerned about the tear out strength of the insert. Any advice would be appreciated.
    Apr 2002
    Webster, Ma. USA
    673
    9
    17
    not answering your question directly, but there are other inserts besides Helicoils. Some are solid whereas you know Helicoils are wound wire. Space to install and the size of the part may be limitations.
    Jan 2006
    Southern Ontario
    2,161
    56
    81
    Well non-scientifically speaking, if it takes you one hammer hit to get that insert in, its going to take that much energy (or probably less) to get it forced out.
    Keenserts are a type you may want to look at, steel tube like bodies with both an internal and external thread that get threaded into the part.
    Dimitri
    Dec 2005
    Auburn, Alabama
    1,438
    114
    121
    Are these inserts for repetitive use? (running screws in and out often) or just for an assembly?
    I've used the self threading inserts in acrylic, polycarbonate, and PTFE (Teflon). They are the style with McMaster P/N: 99362A700
    The example shown are 1/4-20 but they have many more to choose from.
    These were for repetitive use with thumbscrews. Otherwise, my experience with Delrin is that it is strong enough to thread as though it were aluminum.
    The style I've shown are not quick to install however, so you may be looking for a press fit style like you said.
    Jul 2007
    UNITED KINGDOM
    4,189
    1949
    1733
    I wouldn't want to use a press-in/crimp-in type insert in Delrin. There's too strong a chance that it would just pull out. Helicoils or clones thereof should work very well. We've even used them in Oak for retaining handrails with Stainless machine screws.
    May 2007
    Sherbrooke,Quebec Canada
    73
    +1 for key locking insert. I've used it a lot in aluminum and UHMW with good success.
    Martin
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    I used to make parts for NAVY SUBs and one item was Delrin Bearings for the snorkel, The NAVY specified Helicoils in the surface that had fitting stock on it... so that's what I'd use...
    If your application is using the bolt holes and changing the bolt often, I'd look at the type that have the larger thread on the OD and your screw size ID...that type should give you better life of the tapped hole.
    Aug 2009
    South Central Pennsylvania
    Default Helicoil trouble in delrin
    Am I the only one with experience of helicoils being single-use parts?
    Half the time we need to remove the screws from a helicoil in plastic, the coil comes out by a turn or two and the assembly has to be torn down and sent back to the shop. For my money, use either a self-tapping solid insert (not a press-in), or a keensert. Either way, you save the special tap and frequent replacement.
    Aug 2008
    Sussex, England
    3,027
    9
    585
    For attachment purposes tapped holes work fine in delrin. Use very sharp taps and a coarse thread. Go at least 2D deep in good thread and counter bore top to help ensure that Ham Handed Harry doesn't cross thread things. I've gone down to M2 with every success but its real easy to break at tap. Big problem is the ease of cross threading on insertion and the destructive results. Even at M6 'ole Harry won't notice cross threading.
    Proper inserts for plastics, especially delrin and the other slippery ones, should have anti-rotation and anti-pull out features. In smaller sizes these are usually engaged by expanding the bottom part by driving the screw right home, the insert being made with side slits in the bottom third or so to permit expansion. Allegedly the threads on a proper brass insert properly fitted will strip before the insert pulls out. I've seen the heads of brass M4 and M5 cheese head screws sheared off without evident damage to the insert or its retention.
    Mr Mighty Big Manufacturer seems to use ultrasonic and similar methods to fit inserts with exterior patterns to resist rotation and pull out. Many and various patterns out there, each better than the others according to the respective makers.
    Helicoils and delrin don't sound a good match. Timeserts or similar should do better. Preferably glued as well as expanded to help retention.
    Clive
    Jul 2004
    Vicksburg, MS
    4,938
    30
    255
    With Delrin you want a shouldered insert so that when you tighten the bolt it pulls up against the insert NOT the plastic. This will keep you from pulling out. I use the heated inserts that you melt into a hole.
  11. #11
    Apr 2004
    Monument CO USA
    2,058
    9
    107
    PEM does a whole range of inserts for plastics. Ultrasonic, thermal, press in and so on.
    SI Inserts for Plastic from PennEngineering
    Chris P
  12. #12
    Nov 2007
    Alpharetta, Ga USA
    1,763
    111
    134
    I prefer these for Delrin; Mc Master Carr 90248A024. They are thick wall, and have an adhesive seal. No special tools are required to install them, a screwdriver works just fine. They are also available in stainless, and extra thick wall if you have room.
  13. #13
    Apr 2009
    OHIO USA
    38
    UPDATE- In typical engineering fashion there has been a change in material. Now the parts are to be made of UHMWPE so that it is static dissipative. Now I am leaning more towards Plastite screws as I have never had much success with inserts in PE. Thanks for all of your input.
  14. #14
    Mar 2004
    grass valley, CA, USA
    230
    These are made of brass and I THINK are inserted hot to seal in the plastic:
    MSC Item Detail
    There are 8 pages of inserts in this section.....What size thread are you looking for?....
    I know where there 1-2 thousand brass, 3/8-16 inserts available for about $.20 each.....
    Jim
