Results 1 to 19 of 19
Like Tree7Likes
  • 2 Post By ADFToolmaker
  • 1 Post By Limy Sami
  • 1 Post By CWB
  • 3 Post By Bruce Griffing
Thread: Best way to finish inside of cylinder?
    72Zorad is offline Plastic
    May 2012
    Spokane, Washington
    10
    Default Best way to finish inside of cylinder?
    I've got a bit of a unique challenge here.
    I am building a steam/air engine I designed. It has 8 aluminum cylinders that are 4 inches long and the double ended piston is about 2 inches long. It piston has a built in slide valve and the piston/slide valve is made of delrin. All of this means both ends and the center of the cylinder (the whole thing) needs close tolerances as does the slide valve/piston. In other words I want the cylinder bore as perfect as I can make it for it's full length. The bore size doesn't matter too much as I'll machine the pistons to match but it would be nice to have interchangeable parts. I tried a reamer but didn't like the finish as I got a bit of chatter (adjustable reamer at 1.015"). Then looked for hones. I heard Sunnen hones where the best but they only go down to 1.25" and that's actually the cylinder OD so they are too big. I resorted to a brake cylinder hone. It only had 1.15" long stones so hopefully it didn't mess up my dimensions too much. Unfortunately these hones come with 220 grit stones. Way too course, the cylinder is going to 'eat' my delrin pistons so I need to finish them in a manner that removes the 220 grit scratches.
    So, what is the best method to get the bore of the cylinder as dimensionally consistent as possible for its full length and smooth enough for a delrin pistion....I'm thinking 1000-1500 grit sandpaper like finish. The cylinders are currently open at both ends....as in a open ended tube so the bore is very accessible.
    thanks,
    Mark
    ADFToolmaker is online now Aluminum
    Mar 2012
    Hamilton, New Zealand
    235
    Honing is the way to go. Sunnen make hones way smaller than 1.00". The info you have may be for a specific type, of which there are many.
    Mike C. and Davis In SC like this.
    Limy Sami is online now Diamond
    Jan 2007
    Norfolk, UK
    9,343
    Find a hydraulic or automotive engine rebuild shop, they'll have honing equipment that size for wrist pin bushes etc etc, IME charges are very reasonable.
    Mike C. likes this.
    Timw is offline Stainless
    Nov 2005
    N E Florida
    1,835
    For finer grit for the brake cylinder hone buy some self sticking sanding pads in the grit you want and stick them to the hone.
    Mike C. is online now Diamond
    Nov 2004
    Birmingham, AL
    9,840
    I think I'd stop here and take Sami's advice before continuing with the brake hone. The brake hone will give you a smooth surface, but it is probably going to cause taper and, if your cylinders have any porting in the sides, it will go out of round as there is less material to cut there than on the rest of the inside surface. A Sunnen hone holds the stones parallel to each other and at a fixed radius from the center, so they can't cause taper or go out of round.
    Tonytn36 is online now Diamond
    Dec 2007
    Southeastern US
    4,283
    And all that work will be for naught when you install them in the engine. As soon as you put torque or load on them they will distort. They need to be honed fixtured in a manner as close to the "As Installed" condition as possible.
    Jan 2007
    Norfolk, UK
    9,343
    Quote Originally Posted by Tonytn36 View Post
    With the clearances required for a delrin piston with it's higher coeficient of expansion? I wouldn't worry on that score.
    magneticanomaly is offline Hot Rolled
    Mar 2007
    On Elk Mountain, West Virginia, USA
    854
    I'd be afraid that life of uncoated Al bores will be short. I'd use SS or anodize. I've honed cylinders with a homemade split wooden mandrel with sandpaper glued on You need to hone wet, or your stones or paper will load right away, stop cutting, and likely score the bores. I use Diesel fuel. Have a buddy or a kid squirt it out of a detergent bottle. I'm assuming the job won't pay for the "right" equipment.
    9100 is offline Titanium
    Nov 2004
    Webster Groves, MO
    3,100
    Sunnen makes multi stone mandrels a long as you need in very fine grits. You also need to have the correct shoes for the material. First get the bores straight and finished, then have them hard coat anodized. You can run the hone through them after anodizing and get a slick finish. With Delrin pistons, you are not going to be able to run very high steam pressures because high pressure steam is also hot. Besides, Delrin absorbs water and swells. Some investigation of materials and methodology now can save a lot of expense and failure later. The way you are going now doesn't sound very promising.
    Bill
    dazz is online now Hot Rolled
    Aug 2006
    New Zealand
    579
    Hello
    I had a similar problem with racing kart brakes. I had the bores hard anodised to eliminate wear and scouring. This process penetrates the base metal by a thou and raises the surface by a thou.
    Dazz
  11. #11
    DaveE907 is offline Titanium
    Sep 2007
    Spanish Springs, NV
    2,201
    There is only one process that will produce your stated goal, "I want the cylinder bore as perfect as I can make it for it's full length." It's lapping. Lapping can be done with shop made tools to very high standards with some knowledge and practice. If you're not familiar with the process have a look around this site for an introduction.
    Internal Laps, Arbors and Expanders
    The process can be done on a cheap, crap machine by a good operator and be on the money in onesey, twosey numbers such as your job. Hones make sorta round straight holes with decent geometry and surface finishes. Laps take over after they're done with what they can do.
    If you don't need that level of precision adjust your stated goals with finish and tolerance specifications. Perfect is impossible but with enough elbow grease you can get real close, within millionths of an inch for the geometry of a through hole: circular and straight.
    The previous comments about the material choices described for air/steam service are correct, bare aluminum cylinder bores and Delrin pistons don't perform well long term. If it's some sort of model for brief demonstration with air the pairing might meet your requirements. A hint of lubricaton will do wonders for its longevity. Put anything hot (steam) there and the Delrin will expand greatly more than the aluminum and stick it.
    There are other ways to do things, search "hydraulic wear rings" to learn how materials such as Delrin are used inside cylinders for their good bearing properties while avoiding the problems their high thermal expansion rates can cause.
  12. #12
    CWB
    CWB is offline Cast Iron
    Mar 2009
    Lafayette IN
    299
    I design recip engines for a living, and would tell you to try to design and build the best you can, but not go overboard too much. Being that youre designing it yourself, I dont imagine this being a critical application of any kind (please correct me if Im wrong), and would guess you are building this mainly for entertainment. In that case, I wouldnt worry about overbuilding for longevity, simply build it within reason and if you run into issues rebuild it. Reciprocating engines tend to have very tight bore and piston related manufacturing tolerances for longevity relating to thermal growth, but if I read your original post correctly it sounds like you will be running on air. In this case your delrin piston would likely work and tolerances inside the cylinder arent super critical. Even on fuel powered recip engines many of these tolerances and surface finishes arent super critical to actual operation, simply performance. We all know multiple Bubbas who have "rebuilt" junkyard engines in their garages, and getting something like this to run a few hours minimum isnt rocket science either.
    For a good quality hobby project, I would simply bore then run a piece of 600 grit down the bore and call it a day, but I also would use an iron or aluminum piston instead of Delrin.
    gas pumper likes this.
  13. #13
    GregSY is offline Titanium
    Jan 2005
    Houston
    3,740
    Exactly. I doubt you will really be putting hours on this engine anyway. Probably could use a mudball hone.
  14. #14
    willbird is offline Banned
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    There are two types of "honing"...the brake cylinder hone or "dingleberry" hone is an uncontrolled process for the most part, it could level off any high spots I suppose, but it can never really make the bore more round or straight then it is now.
    The "other" type of honing is a controlled process that WILL make a bore straighter and more round than it started out, the sunnen engine cylinder hones will do this, they were originally intended to allow use on and engine that was still in the vehicle however, so they will not work as well probably as the machine tool type sunnen hone.
    Lapping shares some of the same attributes as the sunnen controlled honing process.
    For a lap to work it needs to be softer than the material you are lapping, aluminum makes an excellent lap for OTHER materials, but it will not help you here, I'd guess off hand lead may be your best bet to lap aluminum ? I'd single point bore them, then give them a final lap to make them really nice, it is good to learn how even if THIS job really does not require it :-).
    You MIGHT be able to make up an expanding lap that is knurled on the OD, and wrap some lead roofing around it, or warp it in 50-50 solder :-). Or buy a few lead anchors for concrete nearly the right size and modify them into a lap
    6 in. x 3/4 in. Lead Anchors (24-Pack)-5075-R-001B at The Home Depot
    If your finished cylinder has some clearance between the piston and the bore, the piston will more or less float on an air (or steam) bearing and never touch the bore.
  15. #15
    Metalcutter's Avatar
    Metalcutter is online now Titanium
    Sep 2005
    San Diego
    2,435
    Okay.. Go buy yourself a 1/4 or 3/8 diameter half round drill. Put a chunk of your aluminum in your lathe. Using a standard drill & center drill (for accuracy) drill the hole to a test depth you want, and then follow it with the half round drill which was selected for a finish pass. In effect it becomes a one fluted reamer which can't go over size and can't chatter. Use some real cutting oil.
    The Ol' Man told me the aluminum will expand a bit during the cutting process, and then on retraction it will cool and shrink a bit and the inside surface will become burnished. NO GRIT Necessary. If that works for you then obtain a 1" half round drill. You don't even have to measure anything.
    Regards,
    Stan-
  16. #16
    Jul 2005
    3,714
    Quote Originally Posted by Metalcutter View Post
    Regards,
    Stan-
    Some folks call that a "D reamer" :-). He is talking a 1" bore though...suppose he could make his own D reamer, there are a few threads here if he does a search.
  17. #17
    May 2012
    Spokane, Washington
    10
    Wow! Tons of good info here. Thanks all.
    For clarity it is an air engine....I say steam because almost anyone who builds model 'steam' engines actually runs them on air as it's easier and safer to run a compressor than a boiler. I don't typically like to say 'air engine' as that makes people say why would you use an engine (air compressor) to make air to then turn another engine.....they don't always get that the concept of most air engines are based on steam engines.
    It is just a concept model so won't run long periods (if it runs) so I'm shying away from the metallurgy and challenges of machining different types of metal. Hell, the machining itself is enough challenge for me. I'm not a machinist by trade, this is a hobby. Every day my respect for true machinists increases. Had I known the challenges and skills necessary to become a competent machinist I probably would have taken up latch hooking or paint by numbers.
    I suspect I'm being a bit overzealous about these tolerances but one of my goals is to learn to machine to a high degree of accuracy....might not actually be required for this job but is still a valuable bit of information or a valuable skill for when it is needed.
    Mark
  18. #18
    Bruce Griffing is online now Stainless
    Jan 2003
    Temple, Texas
    1,753
    Another way to get a smooth interior surface is to force a very slightly oversized ball bearing ball through the cylinder. Lube it up and force it through with a press. It will leave a burnished surface that can be borderline shiny.
    mike 44, Metalcutter and Limy Sami like this.
  19. #19
    May 2012
    Spokane, Washington
    10
    Finally finished the engine . It can be seen here;
    http://youtu.be/MiEEkqjOqf8
    It ran right from the get go with no adjustments/modifications required (don't ask about it's predecessor ).
    Mark
