Best way for removeing old Flat head machine screws
Results 1 to 20 of 20
    Aug 2009
    Illinois
    345
    100
    19
    Default Best way for removeing old Flat head machine screws
    What are some good ways to remove old stuck flat head machine screws? Any I've tried kerosene as a thin oil and ground screwdrivers and tool metals to match it up as best as i can but this one screw really wants to round out, but the other three came out with little trouble.
    Jan 2005
    CANADA
    Saskatchewan
    9,432
    1138
    3175
    An impact driver will usually do the trick. In case you don't know, this is typically a tool on which you'd mount a socket with the proper blade in it. To the average guy, its usage may seem a little mysterious because it doesn't look like much
    Then you cock it by turning the socket one way or the other (after the first blow, reset it in the only direction it will rotate). Then put the blade on the screw and hit the end of the impact driver handle with a hammer. The action of the hammerblow simultaneously keeps the blade well seated in the screw and turns the socket a partial turn.
    Jul 2009
    NW Illlinois USA
    324
    34
    89
    Default impact driver
    These work well:
    - Harbor Freight Tools - Quality Tools at the Lowest Prices
    I'm not endorsing HF, just an example.
    Sep 2007
    Woodinville, WA
    1,702
    183
    345
    If impact doesn't work, drill it out with a LEFT-HAND drill bit. Most will just wind out. I rarely have to use an "easy out" when drilling LH.
    Nov 2007
    marysville ohio
    8,623
    2442
    5467
    I just weld a hex head bolt to them, wire feed or tig, works great. I used to remove them from the blades of reel type mowers for a golf course, weld the bolt to the first one, remove it and weld both to the next, all 3 to the next and so on. I would somtimes have 10 welded together. I could get 7 1/4 28 flat head cap screws out in less time than it takes to tell about it.
    Jul 2007
    Alberta, Canada
    149
    20
    10
    Use WD-40. Putting pressure on the screwdriver just hammer it few times. This should work. Using hammer will help you feel how match pressure to put on the screwdriver.
    Good lack.
    Mar 2008
    New Bremen, Ohio
    374
    71
    72
    Default try a brace
    I've had good luck using a brace with a screw driver mounted in the chuck, they come in different swings, 6-14" 8 and 10 being most common. Usually can get a very good old one for $3-$5 around here. The better ones will grip a round shank but all will grip a hex shank . You can get good downward pressure and if you wiggle the crank back and forth gradually increasing the force counter clockwise usually you have success. Too much torque will break off the screw so go easy and use a lubricant and heat if possible. As mentioned already the impact drivers are godsends.
    Bret
    Apr 2008
    Helmer, Indiana, USA
    1,167
    242
    454
    A hammer and center punch works well also. With a center punch mark out near the edge of the head the screw can be rotated by driving the center punch at an angle to force the screw to rotate.
    Dec 2009
    South Yorkshire, England.
    367
    551
    28
    I like the brace idea, welding would put some heat into job and loosen things up and impact drivers are certainly a great help. I can imagine the job Moonlight would have otherwise had with his mower screws which spend their lives soaked in grass juice!
    You would never get the cross point screws out of a Jap bike aluminium alloy crankcase without an impact driver and they don't have to be expensive to work. Pity they never put a bit of lube on 'em when they put them in.
    Steve
    Dec 2005
    Jersey Shore
    3,818
    276
    450
    The older metric motorcycle had tons of these buggers. First try the impact driver as suggested already, if no joy, big center punch mark and drill 1/64 smaller than the shank size. This will usually leave the head on you drill bit, or a twist with a screwdriver will break it off. The shank of the screw will usually unscrew with your fingers after your separate the parts.
  11. #11
    Aug 2009
    Royersford PA USA
    276
    Use one of those screw remover designed to dig into the head of the screw. I can't remember the name for them. if that doesn't work break out the welder.
  12. #12
    Jan 2007
    Massachusetts
    5,105
    642
    1014
    Quote Originally Posted by Kyle Smith View Post
    This is what has worked for me MANY times when I had to remove flathead socket screws from insert toolholders, the ones where Conan The Barbarian had tightened an M2.5 x0,45 screw as though it had to hold back an army.
    Of course I have an impact driver that I try first, but the vast majority of times I have to use the center punch method. I had bought a pack of five Starrett 1/16" center punches to use because all my others just dulled too quickly. I still have all five and haven't had to resharpen any.
  13. #13
    Jan 2005
    The Netherlands
    5,301
    219
    1207
    First thing to try is to take a piece of bar a bit smaller as the head and give it some good blows with a hammer
    In many cases that will do the trick
    Peter from Holland
  14. #14
    Oct 2005
    tacoma washington
    1,338
    27
    Peter, has it right
    if the head of the screw is half inch, just use a half in diameter punch
    and use a couple of solid hammer blows straight down on the screw.
    99 times out of a 100 the screw will come right out.
    bob g
  15. #15
    Feb 2002
    Great Bend Kansas
    60
    Peter and Bob have it right. I've used that method many times. Works 99.9% of the time.
    Gary
  16. #16
    Jan 2010
    Savannah, GA
    27
    If you can get the part onto a drill press chuck a bit that fits the screw slot then bear down on the screw using the drill press and rotate the chuck by hand to back the screw out. By using the drill press you eliminate the possibility of the bit climbing out of the slot and get plenty of torque from turning the chuck by hand.
  17. #17
    Jul 2008
    People's Democratic Republic of Louisiana
    2,557
    562
    266
    Made to work with a rivet gun, but an air hammer with the air regulated down should work.
    SCREW REMOVAL TOOL from Aircraft Spruce
  18. #18
    Feb 2008
    Lomita, CA
    91
    9
    A little lapping compound on the tip helps reduce the tendency of the screwdriver bit to cam out of the slot under torque.
    Davis
  19. Likes MikeS-54 liked this post
  20. #19
    May 2002
    South Central PA
    12,620
    1633
    2777
    Quote Originally Posted by thruthefence View Post
  21. #20
    Feb 2009
    London, Ontario, Canada
    184
    17
    I second the TIG welder approach. This is the easiest way on the old cars I work on. Attached photo is a cylinder block assembly for a 30 Rolls Royce which someone had broken a few of the water jacket studs. When I got it one was drilled below block level and the other two were at block level. I put a #12 nut over each one, a 1/16" tungsten in the TIG. Drew an arc on the stud and with a fine filler rod built it up and into the nut. When cooled they turned right out. Also works well on head studs in aluminum blocks ie my 36 Rolls.
    Peter
