K&H
- Sep 19, 2014
- Cannon Falls
Anyone know of... or heard of... Anything that would work?
I have a lot of 3/8" bolts to cut off. The only thing visible, is the nut and usually a small bit of the bolt sticking through. (technically you can wiggle a wrench in to get to the bolt head) I keep thinking there MUST be something out there... A powered pincher tool of some sort.
I cut a lot of them...
*Taking each one apart with wrenches (impacts) is far too time consuming.
*Air chisels are too slow, and your hands will still be vibrating at the end of the day.
*Torch is too time consuming, and run the risk of nicking the part...
*Simply tightening them with an impact to snap them off almost works, except that many are rusted so the socket slips, and the ones that DO snap off, you fight too long to the the nut back out of the socket.
There must be something out there that can "pinch" off the nut? Something powered? Air, electric, hydraulic...
Charlie
Charlie
