nerdyrcdriver
- Apr 2, 2017
Hi everyone!
I am a student on an SAE Baja team at my college. I am running into trouble trying to bore a larger hole in a part made of 4140 on our bridgeport ezpath lathe. I got an awesome surface finish using recommended feeds and speeds and carbide tooling. But our only boring bar set (10 degree) uses HSS tooling. I have tried everything I can think of and have found online but the surface finish is always bad.
The best surface finish was at:
212 RPM (calculated to be 100sfpm)
.010" depth per pass
.001 IPR
I couldn't find any good videos on how to set up a boring bar correctly. I had the tool angled slightly upward just above the center of the part with a very slight angle on the tool post.
What could I do to improve? Are there any good resources online for how to set up a boring bar?
I feel like some how that I had the tool set up was causing more friction/ware instead of cutting action. No matter what I did it always screeched, though after some adjustment that came way down, but still not perfect.
.001 IPR
