lathehand
Cast Iron
- Jan 31, 2005
- San Francisco Bay Area
I got a bit carried away and rebuilt a Rivett 618S turret lathe. It is scraped in as close as I am going to achieve and I am ready to bore the tool holes in the turret from the lathe spindle using a 2" dia Criterion offset boring head. The holes are slightly oversize at 0.752", tapered and no longer centered with the spindle. I plan to bore to 0.8125 or 0.875" and install a thin wall steel sleeve w/ Loctite and then either rebore or ream to 0.7505". I do not know the turret material, only that it is file soft.
Looking for suggestions on tooling (1/2" shank) and ideas on how to rig a steady feed. I can use the depth stop screws - 3/8" - 24 for infeed by backing them out smoothly, but doing this by hand may be a problem. It would also require something to provide the feed force. I can use the feed lever somehow - thought of using a screen door spring to pull on the feed lever and then controlling the feed by backing the stop screw out. The problem with that is rigging up a stop at the bottom of the hole. Maybe a dial indicator mounted on the bed and reading the turret slide or a solid stop.
It would be nice to get consistent hole sizes for both the sleeve and the final sizing.
I'm looking for ideas and previous experience.
TIA Carl
TIA Carl
