Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > General
General Metalworking, machine tool, and woodworking machinery discussions. Active.
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 11-07-2009, 09:23 AM
Newman109's Avatar
Hot Rolled
The Brits called them "Gland Nuts". It's in my old BSA manual. Sounds sorta dirty, doesn't it?
  #22 (permalink)
Old 11-07-2009, 10:17 AM
Stainless
the castle nut is crenelated like a castle wall sawtooth top. Often used for car wheel bearing adjustment nuts.
Bill D.
For watches the tool to unscrew the back or bezel is called a crab or maybe frog?
  #23 (permalink)
Old 11-07-2009, 11:03 AM
Hot Rolled
That sort of "nut" is called a "lock ring" on some machine tools. Regards Tyrone.
  #24 (permalink)
Old 11-07-2009, 11:09 AM
The real Leigh's Avatar
Quote:
Originally Posted by gas pumper View Post
For some reason the term "New Departure nut" surfaced in my memory.
That's probably a reference to a bearing nut.
Those are thin, very fine threads, oddball sizes.
- Leigh
  #25 (permalink)
Old 11-07-2009, 11:11 AM
Quote:
Originally Posted by Mark Rand View Post
If it holds the prop on to the prop shaft of a ship and is mounted with the aid of a hydraulic pump, it's usually a Pilgrim nut
The Pilgrims had no prop shafts on their ships.
- Leigh
  #26 (permalink)
Old 11-07-2009, 11:15 AM
Quote:
Originally Posted by Billtodd View Post
I popped it into the hole nearest me to check the depth where upon, under just the weight on the rod, the nut spun undone :
It capitulated instantly in fear that you would unleash the combined psychic powers of the assembled experts on its poor self.
Wise decision, nut.
- Leigh
  #27 (permalink)
Old 11-07-2009, 11:18 AM
Quote:
Originally Posted by David Utidjian View Post
The nut that holds the main rotor on a helicopter is called a jesus nut.
And the nut that holds the car's steering wheel is called the driver.
- Leigh
  #28 (permalink)
Old 11-07-2009, 12:47 PM
Cast Iron
Only if it is the hydraulic nut used to force the wheel onto the taper. It is usually removed and replaced with a plain nut called a "boss" nut or "wheel" nut.
  #29 (permalink)
Old 11-07-2009, 01:38 PM
According to a german book I have it's called a "Kreuzlochmutter" (four holes drilled radially). If the holes are not drilled but cut (being square) it's called "Nutmutter". Sounds better, nut?
  #30 (permalink)
Old 11-07-2009, 01:46 PM
Titanium
Capstan nut is correct,I'm sure. Pianos use capstan nuts.
  #31 (permalink)
Old 11-07-2009, 02:29 PM
Toms Wheels's Avatar
Titanium
Yes, Capstan Nut "A nut whose edge has several holes, in one of which a bar can be inserted for turning it." Sci-tec definition
  #32 (permalink)
Old 11-07-2009, 04:37 PM
joecr's Avatar
Hot Rolled
-DU-
At the moment it starts to comes loose, no doubt.
  #33 (permalink)
Old 11-08-2009, 06:40 PM
Quote:
Originally Posted by Pierce Butler View Post
castellated nut?
Nan, the castellated nut is the nut with the six slots in the one end of the nut, allowing the use of a cotter pin to hold it in place..much like a tie rod or balljoint nut.
Now, on the other hand, a CASTRATED nut is any nut that is married for a few years...
  #34 (permalink)
Old 11-09-2009, 09:36 AM
Patrick Black's Avatar
Threaded Collar.
  #35 (permalink)
Old 11-09-2009, 09:46 AM
dfw5914's Avatar
Hot Rolled
It does not matter what you call it because when you go to order a replacement the person taking the order will indignantly correct your nomenclature.
"You want a capstan nut...? nahh, what you are really looking for is called a speed spinner stump drive pancake nut" (while giving you a slightly sideways narrow eyed look)
  #36 (permalink)
Old 11-09-2009, 10:28 AM
DUDE!!!!
Don't post funny stuff like that while I'm trying to eat my soup!
  #37 (permalink)
Old 11-09-2009, 10:46 AM
Cast Iron
That describes some of my co-workers. Nut(cases) with holes in various locations around the periphery of their head.
  #38 (permalink)
Old 11-09-2009, 10:58 AM
Default While we are at it...
I found this little beastie in the lab next door. When queried, the gentlemen in charge told me what it was used for, but not what the name of the fastener was.
It is a pressure vessel for autoclaving. It goes together in the order implied in the second picture. The larger black "nut" is snugged by hand. Then the 1/4-20 SHCS's are tightened to spec with a torque wrench.
Is there a proper name for this system?
  #39 (permalink)
Old 11-09-2009, 04:08 PM
Quote:
Originally Posted by nkuzmik View Post
DUDE!!!!
When you live in Joisey you need a LARGE and varied sense of humor..and a strong gag reflex.
  #40 (permalink)
Old 11-09-2009, 04:51 PM
How about "autoclave"?
- Leigh
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
