Jerry
- Mar 7, 2001
- DeLand,IL,USA
Will heat treatment distort 4140 after machining is finished? Where would you send it if you have no heat treat facilities. I am located in IL. Any suggestions?
TIA
Jerry
TIA
Jerry
Already has ample carbon content to be directly hardenable. Case hardening (or carburizing) is a process that involves even higher temperatures than are used when direct hardening 4140. The intent of the process is to add surface carbon to low carbon steel, so that surface can be directly hardened. Case hardening 4140 does not add much carbon to the surface, but does in fact subject the steel to higher temperatures than you would have used to directly harden 4140. Since you are interested in absolutely mimimal distortion, higher temperatures are definitely the wrong approach. Should you be persistent enough in your case hardening efforts to add surface carbon to 4140, you are asking for considerably less toughness from this really great, tough steel.Thanks for the post John, but why?
Notice
