Bridgeport Series I Table Weight Capacity?
Results 1 to 7 of 7
    Dec 2004
    Strasburg. PA
    154
    9
    Post
    We have a 1994 standard Bridgeport, minus an owner's manual. Anyone know how much weight the table is rated to carry?
    Jan 2005
    Roseville, CA
    3,861
    26
    16
    Post
    I don't have a manual, but most of these mills, including the imported clones, have a table capacity of 750 lbs. That has always seemed like a lot of weight to me.
    Dec 2004
    Strasburg. PA
    154
    9
    Post
    Thanks. We have a 500 lb part to load. Looks good to go.
    Apr 2005
    south Alabama
    116
    Post
    Bridgeport manual says 750 lbs.
    Jun 2006
    Taylorsville Ky
    3,122
    23
    Post
    Unless you have a lot of hang over you have no problem. I have put a lot of weight on them. The knee screw and nut are what carries the load mostly. Be sure to lube the threads well. I tried to find the specs in my book but found none.
    edit: Bridgeport web site spec says 750lb max. A 12"wx18"lx12"h block of steel will weight about 733lb so I don't think I have had over 500lb on any I have used.
    Dec 2000
    Bremerton WA USA
    10,605
    40
    3961
    Post
    That's 750 lb centered on the saddle. Less as you offset the table. I would limit table loads to 100 lb on the end with the table offset to the extreme.
    Turret mills are weak in the saddle department. The saddle is short and narrow meaning the long table demanded by customers these days can be cantilevered out to alarming distances. The concentrated loads on the ends of the saddle wears hollows in the table and humps the saddle.
    That's the beauty of the turret mill design with its two axis head tilt. You can get to every detail of any part you can fit on the table by swiveling the turret and extending the ram. So why is it I see turret mills with the ram straight ahead and the table offset to the max with a heavy awkward part on it?
    The turret/ram design adds 20% to the cost of the mill. Why not use it?
    Sep 2005
    Northern California
    827
    98
    Post
    Back when I used to regrind tables and saddles for B'ports, we did some experiments and concluded that 250 lbs was pretty much their accurate limit if you want any degree of table travel.
    Cyclotronguy
