Broach Styles (A, B, C, etc.). . .what's the difference?
Community On The Web
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Metal Slave
  • 1 Post By sfriedberg
Thread: Broach Styles (A, B, C, etc.). . .what's the difference?
    atomicjoe23 is offline Aluminum
    Aug 2011
    Poulsbo, WA
    124
    Default Broach Styles (A, B, C, etc.). . .what's the difference?
    I was looking at individual broaches today on the Dumont website and see a wide variety of broach styles (A, B, C, etc.) many with the same dimensions available.
    I tried to find information about the broach styles both on the Dumont website and in the Machinery's Handbook and was unable to find any information. Could anyone
    shed some light on this for me? I am primarily interested in American Standard push-through keyway broaches (inch) at this point in time, but I will take additional
    information for future reference as well.
    Thanks!
    Metal Slave is offline Hot Rolled
    Jun 2005
    725
    It has to do with the width of the broach. For size A you would need bushings with a 1/8" guide groove, size B 3/16 & not sure about size C but it is bigger than A & B. All I've used is A & B
    baldwin likes this.
    sfriedberg is offline Titanium
    Oct 2010
    Oregon, USA
    2,975
    Yeah, A/B/C tells you which broachs, bushings and shims are compatible with one another, based on the rectangular cross-section of the broach body. Nothing to do with tooth geometry, etc.
    baldwin likes this.
    HuFlungDung is offline Diamond
    Jan 2005
    Canada
    7,003
    A longer broach can cut a longer keyway, but while this implies that you're better off using bigger broaches, there will come a limitation in how small of a bore you can fit that large broach into. So, you need 'em all if you want to do everything
    Aug 2011
    Poulsbo, WA
    124
    Thanks for the responses guys. . .I thought it might be more involved than that. I never paid very much attention to the broach sets in the shop. . .since they are in sets in a box and I had never needed to order one I didn't realize there were different styles. Pretty straight forward. . .appreciate the help.
    atomarc is online now Titanium
    Mar 2009
    Eureka, CA
    2,389
    It does get confusing. There is a crossover where some broaches will take a B bushing or a C bushing...depending on the ID of the part being pushed. I can't believe DuMont doesn't spell this out. As metal slave indicated, it's all relative to the back side of the broach...not the key it cuts.
    Stuart
    Aug 2011
    Poulsbo, WA
    124
    Nope, nowhere on their website. . .
    . . .here's their brief response to my email inquiry:
    "Good afternoon Joel
    The primary difference in the styles is the length of the broach and the width of the back of the broach.
    Let me know, if this helps or if we can be of further asssistance."
