mark costello
Stainless
- Jun 25, 2001
- lancaster,ohio.43130
I have made some parts out of Aluminum for a customer. Pressed in 1/8" dowel pins, 3/8" deep.
Some came loose, found out later the part is a heater block. I used a .1245 reamer leaving .0005 for a press fit which seemed to press ok, no problems. Customer has no idea of the temperature at which the machine runs, it's just plugged in and goes. I am making replacement parts now and would like to avoid this problem in the future. Obviously 1/2 a thou is not enough, What size should I make the holes this time? The expansion rate of Aluminum is supposed to be .0000126 per degree, assuming 400 degrees means the part would change .005. Is that figured correctly? I am thinking of heading to his place with a Digital thermometer to get an idea of temperature. Any advice?
