hobbes
- Apr 30, 2014
- Washington, USA
Recently the company i work for purchased a 1 inch extruder. We came to find out that at some point in its life it had a couple of extruder pressure disk bolts that had been cut and ground flush to the barrel. We needed to get these out. So the first attempt to remove these was to drill holes in them and try to use a hefty extractor. The drilling process went well enough. Long story short, the extractor snapped in the bolt. Fantastic. Method number 2: attempt to drill out the extractor with a harder drill bit and get a different/larger extractor whilst soaking the bold in penetrating oil for weeks on end. I was not around (honest) when my boss decided to attempt the drilling process. Using a standard right hand drill bit ( you can see where this is going), the bit caught the extractor locked up and snapped the drill bit. Even more fantastic. So now the situation was a broken drill bit in a broken extractor... Now the icing on the cake. Before i was able to do some research and find peoples common solution of getting a punch on the bit and bashing it with a BFH to shatter the bolt and continue to drill out with the proper LEFT hand drill bit, an attempt was made to build up some weld on the surface of the bold and then attempt to weld a nut on that surface to then wrench over the entire bolt.
So this is where we stand. We have a broken drill bit in a broken screw extractor in a stuck bolt soaking in penetrating oil with a bunch of weld covering all of that and nuts that continually shear the weld.
Any thoughts? basically any idea would be appreciated.
