I am wanting to have a 1/2" or 3/4" steel shaft that will only rotate 90 degrees no further. Initially I was planning on a oil impregnated bronze bushing but now that I need to make several of these I am starting to question if the bushing is necessary?
This is a shaft to be set screwed on one side (no movement) and on the other side a block reamed out for a press fit bronze bushing.
For low speed (hand movement) is steel on steel contact okay?
This will be rotated maybe 10 times a day for 10 years.
