Broom stick threads
Results 1 to 13 of 13
    Mar 2004
    Brooksville, Fla.
    479
    64
    57
    Default Broom stick threads
    I have a project
    A proto type of a paint roller type device and need the form and thread dimensions for the screw end broom stick
    The customer had a drawling and the 3/4 -6 acme thread is wrong.
    what I tried to reverse engineer from some threader sticks and nothing is a standard. all different some are 6 thread 5 1/2 and 5
    The thread form the same too !
    I look in the machinist"BIBLE" found nothing..
    Can use some feedback on this
    Robbie
  2. Likes rustdreamer liked this post
  3. #2
    Apr 2005
    powell river bc Canada
    756
    37
    167
    I think the length of engagement is the thing with the broom handle.
    With 5 or 6 tpi and only an inch of "nut" that is a fairly soft material ie wood,
    this is not too critical.The wood will deform to match.I would look at some existing paint rollers and see how their threads are .I have some rollers attached to old
    broom handles.Pretty crude.
    Mar 2004
    Brooksville, Fla.
    479
    64
    57
    I think that some plastic moldmakers would probably know.
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    175
    Quote Originally Posted by rmsfla View Post
    The ones in China ???
    Some broomsticks have a cast metal end now too.
    Dec 2007
    Central Ohio USA
    3,579
    43
    1595
    I got a replacement handle a few years ago that was black plastic over metal thinwall pipe, with the cast metal threaded end -- and a hex ferrule to tighten it with. Got it at Lowe's in the bin with shop brooms. You might check there for something to model. It's fit a few different brooms well.
    Dec 2007
    Las Vegas Nevada
    284
    19
    I went thru this a few years ago. After searching and trying various threads on different handles we came to the conclusion there was no standard. Even managed to talk w/ a custom tap & die company who said they had looked at the problem and could not come up w/ a standard. Now more and more they are making the threads from plastic or some form of alum./pot metal/ mystery metal.
    We solved the problem by redesigning the attachment and us a clamp.
    If you come up w/ a solution please post here I would love to see it.
    thanks
    ed
    Aug 2005
    CT
    7,579
    251
    1561
    'Bout 6 months ago I went through this nightmare of a special project of making a quite intricate device to fit on the end of a plain ol' broomstick handle. Customer had no idea what the handle was going to be made out of, but he absolutely needed that interface.
    I can tell you that after testing approximately 20 different makes and models of female devices ( brooms, pushbrooms, cheap paintrollers, expensive paintrollers, polesanders, brushes and you name it ) by far the most were the closest to a 3/4-5 ACME.
    The only problem was that using the ACME thread specs, they did not tighten up. My app was 1" deep blind hole, so imagine the chip issue.
    Nonetheless, what I came up with was to reduce the major dia by .02 and give it a 5 degree taper.
    Since the handles are made of all kinds of garbage using all kinds of garbage specs ( if any ), the taper had allowed something ( and I could not care less what part of ) the thread to lock up and tighten.
    Anyway, this was my experience with the broomstick female thread. Straight bore, .02 under spec for the major and a 5 deg. taper.
    If this is an internal application, I've found Micro100 the only supplier of a tool which can fit inside the bore and create the thread. Found no taps or threadmills to make a blind 3/4-5 ACME.
    And lastly, my app was in Aluminum. If you have steel or anything else, either walk away from it or kiss your butt goodbye! This thing is one deep thread for it's size and the tool!!!
    On Edit:::
    Sorry guys, I've just checked my notes on the program and noticed that the minor dia also had to be opened by .03! Still straight bore, but .03 over the spec.
    Courtesy of ME Thread Pal, these are the specs I've used a starting point:
    0.7500-5-ACME-4G
    Allowance,--
    Minor Diameter Min,0.5500
    Minor Diameter Max,0.5600
    Pitch Diameter Min,0.6500
    Pitch Diameter Max,0.6562
    Major Diameter Min,0.7700
    Major Diameter Max (Ref),0.7900
    Flat At Root,0.0690
    Thread Height (Basic),0.1100
    Pitch,0.2000
    Lead,0.2000
    Starts,1
    Lead Angle,5.624
  9. Likes tdmidget, SarekS2k liked this post
  10. #8
    Mar 2007
    Washington
    77
    9
    16
    Is it possible that they purposefully get the threads off on the handles? The soft material would make up the differences but mostly the threads would bind a bit more fully engaged, helping to keep your paint roller tools from spinning off too easily if a bit loosened.
  11. #9
    May 2010
    Denmark
    17,281
    3572
    10307
    I have a project
    Robbie
    I don't know how useful these links are but they might be worth a look.
    Wood Thread Cutting Tool
    The Beall Tool Company
    Wooden Broom Handle Stick America screw/thread products, buy Wooden Broom Handle Stick America screw/thread products from alibaba.com
    The thread on this looks like most of the threads I've seen on wood. It looks like a tapered Rd (round) thread. i.e. a knuckle type thread
    International Thread Standards
  12. #10
    Mar 2009
    Brunswick Oh USA
    4,256
    4301
    2495
    Gordon,
    I bought one of those wood threading kits in the early 80's. Back when Jerry Beall was working out of his basement. Worked surprisingly well. Still got it, just don't use it anymore. Back then, the whole kit was 100 bucks. Once set up, you can make some serious threads. Instead of scraping the wood, the router ''machines'' them. Excellent results!
  13. #11
    Aug 2011
    Franklin Ma.
    16
    I think alot of the problem is propriatary, they want you to buy their device and their handle to mount it on.Most will work if you twist their tails enough. Frank C.
  14. #12
    Mar 2004
    Brooksville, Fla.
    479
    64
    57
    Quote Originally Posted by SeymourDumore View Post
    On Edit:::
    0.7500-5-ACME-4G
    Allowance,--
    Flat At Root,0.0690
    Pitch,0.2000
    Lead,0.2000
    Starts,1
    Lead Angle,5.624
    Thanks Guys for all the help,,Made a automatic taping machine for wooden blocks
    Made the tap up and it works fine.
    The fit was "just right"
    Robbie
  15. #13
    Apr 2002
    Syracuse, NY USA
    9,588
    16
    538
    how about using a taper either with a spline or draw bar type mechanism, or how about a taper on a square shaft? you might need a cam lever or a threaded nut to pop the two apart. . The regular threaded extension handles allow the roller to rotate. Many times I have shot a screw thru these connections when doing serious painting.
