Hi, I have searched the forums looking for my solution but cannot find the right fit. I readily find single load point data on loading of I-beams, but not on distributed loading.
Originally, I was going to repurpose hand-hewn beams removed from my early 1800's barn to build a post and beam straw bale home with a flat living roof. My wife and I decided to use several sliding patio doors in our south-facing wall to assist in our lighting, summer cooling and winter heating needs. As a result, a span in our south-facing wall has increased from a practical 10 feet to a more daunting 20 feet. I have several steel I-beams and need to be sure that if I use one of them instead of a wooden 10" x 10" x 19' oak beam. Can I safely support 600 lb solar panel installation, 2 lb/ft2 insulation, 2 lb/ft2 roof trusses, 3 lb/ft2 3/4 plywood sheathing, 25 lb/ft2 living roof load and 60 lb/ft2 snow loads. The area that the I-beam will need to support is 19' x 10'. So, from my figures, a 92 lb/ft2 load or a distributed 18,080 lb load. My I-beam is 231" long, 13 3/4" tall, 5" wide and has web 1/4" and 5/16" flange. This beam would be supported at each end, but if required, could get additional support from a box beam above the sliding patio doors. Any assistance would be greatly appreciated.
