projectnut
Stainless
- Mar 4, 2006
- Wisconsin
In the last few days I've had to make a number of small parts out of 6061 Aluminum. Some needed to be bored so I picked a standard HSS boring tool. The first couple parts went fine. I was using WD40 as a cutting fluid as I have done in the past when the all of a sudden I started getting a build up of the aluminum on the cutting edge. At first I thought it might need to be sharpened so I did a close inspection. It looked fine so I took it to another lathe and chucked up a piece of 316 stainless. It cut the stainless just fine. I took it back to the first lathe and tried boring again with the same results.
Rather than fool around with it I just grabbed another bar. This one had a brazed carbide tip. It cut just cut fine. Not only did I finish the part that was in the lathe, I made 3 more without any problems. Any ideas why the first HSS bar wouldn't cut the aluminum without a buildup, but did just fine on the 316?
