Strostkovy
Titanium
- Oct 29, 2017
I know radial loading on ballscrews is frowned upon, but I've only heard of it in the context of misalignment with linear rails. For some simple projects it is easiest to just have a gantry float on a double ballnut, supported solely by the screws and their end bearings.
Assuming load is light relative to ballscrew diameter such that deflection isn't an issue, is there a reason not to do this? I would specifically use a double nut so that parallelism between the nuts and the screw is maintained, without having to add an additional rail.
