deltaenterprizes
Stainless
- May 9, 2006
- Longview,TX
I have a 2'' milling cutter that uses triangle shaped insrets with the following dimensions:
Tip to tip .577"
Tip to Base .507''
Thickness .127''
No hole in center
11* relief angle
Nose radius .025"
I can barely read kc910 written on the insert.
From the chart in the ENCO catalog I have TP?N _ ???
Can anybody help identify these inserts?
Tip to tip .577"
Tip to Base .507''
Thickness .127''
No hole in center
11* relief angle
Nose radius .025"
