i_r_machinist
Titanium
- Apr 12, 2007
- Dublin Texas
I have to make a valve gag out of titanium. It will be welded after tapping. First, I can't remember ever tapping Ti. I know that if you let a drill dwell it will work harden like hell. Any problems tapping 1/2"-13 by 1.25" thru? I'm planning on putting 1/4" beads on the sides. Warpage or hardening problems? Post weld heat treat?
Engineers are beating the doors down.
Any help much appreciated!
i_r_machinist
welds will be along the length of the cylinder. Cylinder is 1 1/2" od 3/8" long with two 3/8" grooves along the side. Plate is 3/8" thick.
i_r_machinist
