Long Tom
Stainless
- Aug 21, 2011
- Fiddlefart, Oregon
I posted this on the machine-specific subforum but it hasn't had any replies, so I'm posting here for the extra eyeballs.
Went out to the shop yesterday to do a small a job for a customer for delivery today. Hadn't used the lathe in several days. When I was setting up for the job (bunch of 12mm bored holes) I started the lathe up just to warm the spindle a bit. The last op I'd done on it was power-tapping a bunch of M6 holes in 4140; for that reason, the carriage was all the way over against the micrometer stop, which was hard against the headstock.
As far as I can tell, when I started it, the carriage feed lever was UP for some reason. Maybe I bumped it?! A mystery. It's possible it was up for some time while I was power-threading and I hadn't noticed it. Like I bumped it while leaning over the carriage swapping parts in for tapping. Ugh.
Now, the carriage is virtually immovable using the hand wheel. The machine power feed can still move it without apparant strain, but, as a data point, it's noticeably harder to engage and disengage the carriage feed lever. From that, I infer that the problem is in the carriage, not in the headstock.
I'm hoping that a machine so obviously well-engineered has a mechanical "fuse" to prevent any real damage from dumbshits like me in this circumstance. A shear pin or the like. Otherwise I guess I'm looking for bent parts or messed up rack and pinion stuff on the handwheel.
Before I start taking things apart, if anyone has any info on this I would greatly appreciate it! October is my down month (deer and elk hunts) so I'm under the gun to get a bunch of work done now, and most of it goes through this machine.
Really thankful for any help guys. Feeling like an idiot here.
