Connor_U.
- Feb 21, 2016
- Wisconsin, USA
Greetings!
First time poster on this forum...hoping to get some help with a challenging task I am encountering at my new job.
I have recently taken a position at a paper roll service shop as a CNC drilling machine operator. Essentially, this machine is a modified lathe which has 180 drilling heads ganged together with a spline shaft, and is designed to drill holes into suction roll shells for paper machines.
Our company specializes in rubber and polyurethane covers, but we have had a bear of a time dialing in our drilling to give us good results in softer polyurethane (20-30P&J, or roughly 80-90A durometer). We have had problems maintaining hole size (usually dealing with hole sizes shrinking as much as 20%), as well as hole quality and appearance.
Has anyone on the forum had experience drilling/machining polyurethane? Our machine has some limitations, primarily with spindle speeds (2000rpm max), so feed/speed settings are somewhat limited. We have had mixed results with coolant vs. dry machining as well.
We have had promising results with some test drilling with brad point bits, but we worry about their longevity over a full drill job. Most of our drill jobs require bits to withstand upwards of 1000-1500 drill cycles or more...because of this, we have been reluctant to dive in with these bits for a full job (any drill breakage in a new cover is very bad).
Anyone have any advice, or sources of information we could use to help improve our performance with this material?
Thanks in advance!
Connor
Thanks in advance!
Connor
