chasing tapped hole with roll form tap
Results 1 to 10 of 10
    Dec 2017
    9
    Thumbs up chasing tapped hole with roll form tap
    I have some 3-56 i.d. threaded parts, mild steel. The male threaded mating parts are oversized from heat treat and won't fit now. Can I use a H3 roll form tap to chase out (enlarge) the threads so the mating parts will fit? Should I drill out the holes a bit first?
    Jun 2013
    Oregon
    976
    240
    566
    How hard are the mating parts? Roll forming has its limits concerning material hardness.
    Nov 2017
    74
    63
    60
    Remember that roll forming doesn't cut, it just pushes the material. With the thread already fully formed, there may be nowhere for the material to go without enlarging the minor diameter. Other than strength of the tap, is there a reason not to use a cutting tap?
    Dec 2017
    9
    Quote Originally Posted by MrWhoopee View Post
    I haven't found a cutting tap more than H2 oversize. I am thinking I need H4-5.
    Btw this will be done by hand...
    Dec 2017
    9
    Quote Originally Posted by Gobo View Post
    The hole is soft. The male threaded part is hard, like 50-60 Rc.
    Oct 2010
    Dewees Texas
    1,720
    23
    422
    If I was doing a bunch of these I would buy more than one tap in case one breaks, if this fits, try one form tap and have back up cut taps in case it does not work. A lot of commercial nuts have a fairly low percentage of threads so they will have room for a little displaced material from forming. If the nuts are plated a form tap may leave some of the plating in the threads.
    Let us know how it goes and we will all be smarter when you finish.
    Jun 2013
    Oregon
    976
    240
    566
    Quote Originally Posted by welder2022 View Post
    What percentage of thread does your female part have? If it is anything less than 70, your deformation will be so slight that a form tap will probably work fine.
  8. Likes MrWhoopee liked this post
  9. #8
    Feb 2005
    8,205
    11101
    9114
    MSC has Hertel spiral points that are an H4..
    I was thinking taps for plating, but a quick look didn't find anything
    under a #10.
    How many of these do you have to fix/modify???
    How far over are the male parts? Is it just scale? Did they
    damage the treads somehow? Or did they just grow??
    A 2.5mm X .45 is a standard tap, and is almost identical to a 3-56, except
    for a tiny pitch error of about .0015".. I wonder if the pitch error would
    open things up enough for your mating parts to fit.
    Here is a bad idea.. Put a regular old #3-56 in an electric drill, and then run
    it in and then run it out, take it out, put it back in, rinse repeat... I guarantee
    you will open those threads up after a few passes. DO NOT ask how or why I know this.
    If you are making the parts from scratch and are rigid tapping, tap once and then do
    it again, but start a few thou difference in height.
  10. #9
    Mar 2011
    Geneva Illinois USA
    4,583
    1794
    1697
    Actually, unless you order differently, I have found that H3 is the normal tap size. If you snoop long and hard enough, you should be able to get 4,5 and possibly 6.
    Tom
  11. #10
    Jun 2013
    Oregon
    976
    240
    566
    Quote Originally Posted by Bobw View Post
    under a #10.
    How do you know?
  12. Likes Bobw liked this post
