szilvesztera
- Feb 11, 2018
Hi, newbie here. I've been wanting to get into machining for a while now, as a hobby, and I finally purchased my first piece of equipment. It's a Wabeco D2400 german benchtop lathe (bought used for 950 USD equivalent):
It's 220mm swing with 500mm between centers, so around 9' x 20', comes with a 100mm/4' three jaw chuck. The first addition I want to make is definitely a 4 jaw independent chuck, and I think the best size would probably be 5' which I can get new for around a 130 bucks. I live in Romania, so old USSR gear is available for cheaper, but the sizes start at 160mm/6'-ish. I can get a 160mm 4 jaw independent for 50 bucks or so. Do you think this little lathe could handle a chuck that size or should I just bite the bullet on a new, more appropriately sized chuck?
Also, I want to just pour a big slab of concrete and bolt the lathe down to it to improve stability, do you think it noticeably helps? If you have any quick and easy improvement/first step ideas, I'm all ears.
