Clausing 5900 series as a starter lathe..
Results 1 to 5 of 5
    Dec 2008
    Virginia
    96
    60
    36
    Default Clausing 5900 series as a starter lathe..
    What's your opinion of the Clausing 5900 series as a "starter lather" for the hobbyist? All the projects I have in mind are relatively small one-off jobs. It seems like this lathe is a good option for the hobbyist (widely available, relatively cheap for a high quality tool, parts can be found, etc...)
    Feb 2006
    Indiana
    11,737
    393
    2966
    My 5914 is not my first lathe, but it is the last engine lathe I expect to buy. I have had it 25 years and it is still as good a lathe in that size range that I have ever seen. I added a Newall DRO last year and now that I have used it, decided that was a smart move.
    Larry
    Jun 2004
    North Texas, USA
    478
    Default Clausing 5900 as first Lathe?
    A 5900 series could be a good first lathe - but, it seems most of these are the variable speed models. If you get one that is variable speed, I'd recommend being very sure that the vari-drive is in good shape. That can be hard for a first time lathe buyer to do, so for that reason, I'd recommend staying away from the vari-speed Clausings in the 5900 series for a first timer.
    This lathe was also available as a step pulley model - I'd say go after one of those, maybe add a VFD for single to three phase conversion requirments, and get the bonus of variable speed within the ranges provided by your pulley steps.
    If you do get a 5900, and think you're going to want a steady rest, try to get one with the machine, as they're hard to find right now. Interestingly, the 5900 series did seem to get lots of turrets sold with them, so that can be an easy to find part, if that interests you (probably not right away for a first lathe).
    Lots of good deals out there right now on lathes that would be good for first timers - I would not overlook Clausing / Cochester, Sheldon, Logan, South Bend, etc. Usually a 10 or 12 inch model might be a good choice (the 5900 series is 12 inch). I'd say get something in as good a shape as you can afford, with as much tooling as you can, hopefully that can pass at least 1-3/8" diameter work through the headstock, and accepts 5C collets. Personally, I think threaded spindle mounts are OK, I like L series (long taper) better than threaded, and D series cam lock spindle noses the best. Try to get a collet setup and a 4 jaw chuck with the machine, if you can.
    Don't forget about the tooling, that can easily double or triple your bare machine cost.
    Be sure and read Dave Fickens' (sp?) article of Advice on Buying a Used lathe, and In (modest) Praise of klunkers. You can find them at his website at: mermac.com
    There's my 2 cents or mabye a tad more....
    Apr 2006
    Fort Worth, TX
    1,303
    25
    26
    I agree with every point Jess makes. But keep in mind, in this case anyway, every deficiency is an opportunity.
    All of the typical vari-drive problems have been addressed on multiple on-line forums, so fixing any problem will just be a good opportunity to hone your lathe operator skills. I guarantee, once the lathe is up to snuff, it will be a joy to use.
    And once you have used a lathe with the combination of variable speed drive and a clutch/brake, it's total misery using a lathe without those features.
    Jun 2007
    Mass
    380
    24
    32
    I have a 5914 Variable speed. I love it. I stepped up from a couple of 9" South Bends. If you go the route that I went (starting with small belt driven machines) you will definitely appreciate what the 5900 can do.
    If you can swing it and have the room get it.
    If you need to do metric threads you may want to pass. They have some crazy and super rare banjo and gear assembly that costs like $3K!
