Need some direction. I'm having problems with the forward/reverse knob on the apron. It's coming out of gear when engaged. After dropping the pan on the bottom of the apron and seeing the gear, it seems like the bushing and/or spacer are not there. The gear loosely moves all around the shaft. This shaft and gear are not easily accesible. They're way up inside the apron and there's a circlip capturing them. So, my question is..... Does anyone have any experience with this. How do I get that shaft out without removing or disassembling the apron. I have a PDF drawing but can't seem to attach it. Thanks
