din 64997/iso15488B sais to measure runout of er (other?) collets at 2.5-3.5 diameter. up to 6mm runout is supposed to be 0.015mm and then 0.02mm. for 3 mm diameter its 10mm from collet, for 10mm diameter its 25mm from collet. for larger it probably doesnt matter that much.
drill chucks are measured at 50mm for 3mm diam. and 100mm for 10mm diam. (according to roehm.)
no idea how lathe chucks are measured. mine has 0.02mm at chuck and 0.03 at 60mm (forkhardt 250).
i can get no spec. er collets (so supposedly 0.015/0.02), 0.01, 0.007 or 0.005. hardinge seems to spec. 0.01 on er. quality is a big problem. i bought a er25 set of "0.007" to be sure its good. it was from an idustial supplier and it was total crap, the bores even had ridges in front. were $8 a piece. sent it back. bought a 0.005 set at $15 per piece. terible, no ridges, but smaller sizes rusted inside, i have a pic. of all the shit that came out of the set after vibatory cleaning. the 16mm collet averaged 25 micron at collet and 62mu 40mm out. 6mm was 5mu and 4mu at 40mm. 3mm was 5mu and 1.5mu at 7mm. this support the theory, that spindle axis and tool axis are two lines in space that do not have to touch and the angle between them is unknown. interestingly the 6mm collet, although rusted inside has 5mu and 4 mu at 30mm (i will keep it, send rest back).
so i got myself a regofix nut and the runout dropped by 50%.
i then bought a regofix up (ultra precision) 10mm er25 collet at $40 and with the regofix nut its within spec. of 0.005mm at 2.8/5.2/6.8 mu at 3/20/40mm compared to the former collets 10/22.5/31mu with the regofix nut.
roehm spiro drill chucks are spec. at 0.05mm run out and albrecht is 0.04m. (had to sent spiro back twice.) so for 10mm its at 100mm. so roughly 3x colet runout. 4/3 x = 0.013mm. similar to "standart" er collet.
above was measured with a holder that shows no movement on a 0.002mm test indicator on top and botom of taper, and validated by a a 0.0005mm graduated hicator.
so, stating collets are much more accurate than chucks is pretty brave.
is there any u.s. standart for collets and chucks? i have seen 5c collets up to $100 per piece. is the precision up to the manufacturer? so, a set of precision 5c collets will be severat thousands bucks?
