ewlsey
- Jul 14, 2009
- Peoria, IL
OK. There are many things that I read over and over here and things I used to hear in the shop that are just plain old myths.
So, let's clear a few things up.
I'll start:
1) You can't/shouldn't cut through a flame cut edge. Maybe this was true in the old days of HSS and poorly controlled NC torches. In the carbide era, this is a non issue. The scale from the flame cut is a bit abrasive, just like hot rolled mill scale, but it is not hard. Mild steels can't be hardened this way, there is not enough carbon.
2) Tapping takes a lot of torque. I'm guessing this is a common myth because it feels like a lot of torque with a tap handle. Even the wimpiest Bridgeport should be able to tap 3/4-10 with the back gears in low. Even small VMCs usually have plenty of torque for this kind of operation. Form taps take more torque, but are rarely used in large sizes.
2B) Taps need to be held in special collets. Related to the last one. I wish I had thought of those ER tap collets. What a racket. I've tapped bazillions of holes with taps in regular ER collets without issue. This includes form taps up to 5/8".
3) Moly Dee/whatever oil is required for tapping. Maybe in some god awful material. For 95% of material, a regular flood coolant with an EP additive (they all have that) will work just fine. Keep the concentration around 8-10%. I've tapped bazillions of holes with nothing but flood coolant. That includes form taps. The sticky oil is really a detriment in really stringy materials like aluminum. It can trap the chips in the flutes.
4) Form taps don't work for XYZ material. I haven't machined everything, but I've used form taps in tons of different materials. The only things you can't tap with a form tap is cast iron (brittle materials), steel over 32RC, and most plastics. It works great in 304 stainless, mild steel, aluminum (including 7075), and tool steels up to 32RC. I do use oil with the tool steels, but everything else is run with just flood coolant.
5) Carbide drills chip/break in steel. I'm guessing this is happening to the manual guys. Carbide drills need a lot of feed. Even small 5/16" drills should be fed at .0125/rev. I've drilled bazillions of holes in all kinds of steel with carbide drills.
6) You can't peck with an insert drill. Why the hell not? I've done it plenty of times with plenty of drills. Never an issue.
7) You need to spot for HSS drills. BS. Holes are not precision locators. If you need precise locations, a drill should be the first step in a multi-step process. A good quality, sharp, HSS drill should hold .02" true position all on its own as long as you are drilling into a flat machined surface. If you need a chamfer on the hole, a spot with a 90 degree spot drill to the chamfer diameter before drilling is a handy time saver. For general clearance holes, it's not needed.
8) Coated drills won't work in aluminum. Sure they do. Black oxide is not the greatest for this application, but it's not going to self destruct. You need lubrication for aluminum. Once again, I've drilled bazillions of holes in aluminum castings with TiAlN coated carbide drills.
I'm sure I will come up with more. I'm interested to hear what folks have to say.
I'll start:
