Commutator refinishing?
Results 1 to 6 of 6
    Jul 2006
    Little Rock Arkansas US of A
    98
    Default Commutator refinishing?
    I know I'm just missing something I should already know, but I'm having one heck of a time getting a smooth finish on the copper armature segments of a series wound motor with brushes. I get bumps and boogers instead of smoothness. So, all you great guys, how should I sharpen my HS tool to cut copper?
    Mar 2009
    4,062
    79
    662
    Your question should include what method you are using. Such as:
    I have the armature chucked onto my lathe and....
    Dec 2008
    AZ USA
    210
    16
    This is the tool I use, hand ground and honed sharp. It is narrow because some armatures I do have a balance ring right up next to the commutator.
    Attached Thumbnails Attached Thumbnails img_0620.jpg   img_0621.jpg   img_0622.jpg
    Mar 2009
    peterborough,ontario
    I worked at General Electric for almost 25 years and finished comms from 8 inch to 38 inch. We used a diamond finishing tool. About 25 degrees and slow feed. Small radius on tip. Try the same for HSS. The worst part was deburring after finishing the comm.
    Jun 2009
    Boonton, NJ
    309
    288
    19
    I did this in the 60's,and 70's.
    The radiused tool shown will work the best and give you a finish that won't need to be touched after turning.
    Spin it fast, like it was alluminum. slow feed. no coolant or oil. light cuts.
    I hated cleaning out (relieving) the mica without screwing up the copper.
    Jul 2006
    98
    Default Thanks, Everybody
    Thanks for the responses. Wish me luck!
