I have quite a few BT40 holders with M16 pull stud threads that were given to me. I know they are no use in my Fadal 4020 because of tool changer compatibility, but I have a Series II Bridgeport with a 40 taper and 5/8-11 drawbar. I share tooling between them by removing the pull stud for use on the Bridgeport. SO.... My question is has anyone converted the pull stud threads on a tool holder from metric to inch? Or is it even an idea worth entertaining? And if so what would be your M.O. to achieve it? My first and only thought was to use a Helicoil/Recoil, ironically the dia. of the bore just before the threads and also the M16 thread major dia is the exact same size of the drill used for 5/6-11 recoil at 21/32 (16.5 mm). I don't see an issue with the slight reduction in wall thickness of the holder at the pull stud as a result of doing this. Please keep in mind I'm just a broke homegamer so free holders + some work is very beneficial to me. Am I missing something that could cause operability/safety concerns by doing this?
Thank you in advance to anyone willing to chime in, give advise, experiences or even just calling me a for even trying this,
JustSteve
JustSteve
