Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By gnorbury
Thread: Converting NPT tap to NPTS
    mm
    mm is offline Aluminum
    Mar 2003
    NE Iowa, USA
    77
    Default Converting NPT tap to NPTS
    I need two 1/2 inch brass elbows with one leg NPT and one leg NPTS. Tried Google and McMaster and cannot find any.
    McMaster has a 1/2 NPTS tap, but it is over $50+. This is way too much for just two threads.
    I have surplus NPT taps. Can anyone see a problem with picking up the major diameter of NPTS on the NPT tap and just
    grinding out all of the larger threads?
    This is for a fuel tank vent. It needs to be liquid tight, but almost no pressure.
    Thanks --mm
    EDIT: Sorry, I think the initials are wrong. One leg needs to be tapered, the other straight.
    WHHJR is online now Hot Rolled
    Jun 2009
    Near:Louisville, KY
    780
    NPTS will not hold liquid or anything else tight. It is a mechanical thread.
    gnorbury is offline Hot Rolled
    Mar 2006
    Oxford, MD
    531
    Quote Originally Posted by WHHJR View Post
    NPTS will not e liquid or anything else tight. It is a mechanical thread.
    I presume by "NPTS" the OP means straight or NPS threads. This being the case, you obtain a liquid-tight seal by using a fitting that has a flange and crush washer, or an o-ring.
    JoeBean and Gordon B. Clarke like this.
    rons is offline Stainless
    Mar 2009
    San Jose, CA. USA
    1,399
    Quote Originally Posted by mm View Post
    For $50 it is probably a import. I know 1/4 straight taps in that size are about $100.
    I think you are a fool if you are playing games with pipe threads on a gas tank to save a few bucks.
    Besides if you try to convert a fitting from tapered to straight the profile of the finished thread will
    not be all straight. Get a 3/8 fitting and enlarge to 1/2 is the way to go, if you can't find any 1/2 elbows.
    Sea Farmer is offline Titanium
    Mar 2006
    Cape Cod, Massachusetts
    2,894
    Victor has the taps. Some USA made, some import, but they will tell you.
    1000's of taps - inch, metric, special, pipe
    I've bought from them and been satisfied with their service.
    Just a pressure vent? Let's out fumes in the hot sun? Must be, but why did they bother to design a part that requires 2 tools? Wouldn't hurt to make both tapered even if not required.
    Anyways, these guys probably have the tap you need in some quality or other.
    gas pumper is offline Cast Iron
    Jun 2009
    Boonton, NJ
    294
    You want a bulkhead fitting. straight threads on one side and pipe on the other. Or straight to AN and go right to the hose. Or weld a bung in the tank and use pipe thread into the tank.
    metalmagpie is offline Hot Rolled
    May 2006
    Seattle
    839
    Just skip the bulkhead fitting and weld a pipe stub to your tank. Use a union or a pipe fitting to connect to the stub.
    Heavey Metal is offline Stainless
    May 2011
    1,697
    A male npt and npts will both screw into and seal in a npt female fitting.(neather will seal in a npts female)
    A npts tap is for producing a nut (used in a bulkhead situation)
    If it leaks tap the fitting with a nptf (if you have enough room)
    rusty ripple is offline Cast Iron
    May 2006
    new orleans
    447
    mcmaster has nps elbows. look for nps, not npts as mentioned above. not sure why but people assume npt to stand for nat'l pipe thread, when it stands for nat'l pipe taper. nps stands for nat'l pipe straight.
    you can also cut and weld fittings. i worked in a hydraulic hose shop and we used to do this all the time when we couldnt find the adapter we needed. just two of what we did need in half and weld them together.
    May 2010
    Kolding Denmark
    7,289
    Quote Originally Posted by rusty ripple View Post
    I've just looked in ANSI B.1.1 (AMERICAN NATIONAL STANDARD INCH DRYSEAL PIPE THREADS) and in §1.3 states:
    Each of the letters in the symbols has a definate significance as follows:
    N = National (American) Standard
    P = Pipe
    T = Taper
    S = Straight
    F = Fuel and Oil
    I = Intermediate
    Just proving you're right
  11. #11
    t.jones is offline Cast Iron
    Jan 2010
    Dresden On. Canada
    256
    I would have failed Machine shop in Gr. 10 if I refered to a taper as a thread. ---Trevor
