Results 1 to 11 of 11
    Kelly Anderson is offline Aluminum
    Dec 2004
    Strasburg. PA
    144
    Default Corner Radius on Rectangular Tubing?
    I am working to design a part to fit over 1" x 2-1/2" rectangular steel tubing which hasn't arrived yet. Is there an industry standard that calls out the exterior corner radius for this size of tubing?
    Finegrain is offline Titanium
    Sep 2007
    Seattle, Washington
    3,146
    There's a bunch of variations on this theme. "Standard" rectangular tube radius will vary with wall thickness. I'm sure there's also "low-radius" square steel tube, like there is in Al.
    Can you make the inside corners of the female part sharp, so that it doesn't really matter what the radius of the male part's corners are? (That sounds dirty. It wasn't meant to.)
    Regards.
    Finegrain
    johnoder's Avatar
    johnoder is online now Diamond
    Jul 2004
    Houston, TX USA
    18,475
    At least two wall thicknesses with considerable variations from one corner to the next to be expected.
    I.E., on my 3 X 6 X 3/16 wall in the shop, the exterior corner radius is about 7/16 to almost 9/16". Not necessarily uniform radii, either.
    John Oder
    adama is online now Diamond
    Dec 2004
    uk
    4,706
    Lots of box in this country is supplied to a std set of ratios, well pritty near any rate. 1 corner is oftern diffrent to the other 3 though, but this is generaly only on 3" Square and 1/4" Thick upwards. The smaller stuffs held pritty good
    dan s is offline Plastic
    Nov 2006
    Central IL.
    32
    I asked this myself a while back on another forum. the answer was 2-3 times wall thickness.
    dfw5914's Avatar
    dfw5914 is offline Stainless
    Apr 2006
    Fort Worth, TX
    1,276
    Like Mr. Oder says, the standards (or at least the end product) are pretty loose. I have noticed a lot of variation from one stick to the next in the same bundle.
    GregSY is online now Titanium
    Jan 2005
    Houston
    3,719
    One area where you will find the tubing makers do not vary a lot is in wall thickness. The standard allow for something like a +/-10% variation from the stated thickness and you can be sure they will all be right at 10% below. For example, go measure some 5/16 wall tube and it usually is right around .031 shy of .312.
    Dec 2004
    Strasburg. PA
    144
    Thanks to everyone for there prompt answers! Makes me feel better that I couldn't find a standard.
    AAB
    AAB is offline Banned
    Jul 2006
    Melbourne,Australia
    618
    Kelly,
    According to the U.S., AISC Steel Construction Manual, hollow sections down to 2 x 2 square & 3 x 2 rectangular tubing have a nominal outside radius of 2 x thickness.
    Regards from Melbourne,Australia,
    AAB
    bob ward is offline Aluminum
    Jul 2007
    Laidley, SE Queensland
    159
    Quote Originally Posted by GregSY View Post
    I've used a fair bit of RHS over the years, and yes all the suppliers are remarkably consistent in this area. The tube is always spot on at the lowest specified thickness.
  11. #11
    Jul 2007
    159
