rata222
- Jan 20, 2009
- North Carolina
Anyone know the correct name for this tool?
I received this plate from a retired Mold maker, He called it a lapping plate but wasn’t sure of the correct name. You do not charge it with abrasives like a normal lapping plate. The serrated edges are extremely sharp and used for removing metal.
He said an example of usage would be: if you had to stamp a number into a ground surface - you would then run the part over this plate to shear off any raised spots left by the stamping.
Anyone know the correct name for this plate – or who sells them? I would be interested in any additional information of where and how it is used.
Jim
Jim
