choppero
- Jan 25, 2011
- New Mexico
I am taping a 5/8 x 18 hole for a breech plug on an in-line black powder project. I drilled a 37/64 hole with the barrel in the lath using the steady rest and running true to the bore. Barrel is Green Mt 50 cal, 4140 steel. I started the tap in the lath using the tail center to keep aligned. My tap was purchased from a local screw supply house. I have a plug tap that measures .630 OD. It will not cut more than about 1/2 inch and gets too tight to turn. Good supply of cutting oil and I have to clear the chips 5 or 6 times per revolution on the tap handle. I'm wondering if this tap is over limit in size? I'm ready to call MSC and order one of theirs. But not sure of the H limits. Any help would be great.
