bmikkalson
Hot Rolled
- Jan 20, 2010
- St, Paul MN
Why when I buy mig spool it does everything .035 , when I buy arc rod their about 100 options???
you mean filler rod?
If I go to the welding store I can get mig wire er70 or flux core basically 2 sizes. .023 or.035 .
If I want arc welding filler rods. I can get tons of choices.
If I want torch welding rod, I have one choice.
I suggest that you take some welding courses or hire a welding engineer.
.035 what? And, it does not do everything!
100 options on rod? I think you're off by a factor of at least 10.
I know a good welding engineer in Owatana.
JR[/QUOT
That was helpfull , perhaps you missed where I was hoping to be educated on the forum.
Got your post count up!You need a better welding store.
.If I go to the welding store I can get mig wire er70 or flux core basically 2 sizes. .023 or.035 .
For starters, they are two different welding processes.
With MIG, the shield gas acts as the shield and flux.There is also flux coated wire which eliminates the use of the shield gas but then you have a flux that must be removed when the weld is complete. This usually just falls off if the weld process is setup correctly.
With stick, the electrode coating becomes the shield and flux.
With MIG, there are different wire alloys that should be matched to the base metal.
With stick, there are different flux coatings and filler alloys. These must be matched to the conditions, base metal, and weld position.
Stick welding is traditionally constant current. Mig is usually constant voltage. This cause differences in arc characteristics, weld flow, and base metal heat transfer.
With stick, you match the weld rod size to the heat you need.
With MIG, you can vary the voltage, current, and even the weld mode such as short circuit vs. spray transfer.
MIG wire dia. is somewhat limited by the gun and wire feeder. There are other sizes available than the standard .035 and .045.
For doing heavy weldments, stick and subarc are both popular processes as they have the ability to deposit much more weld material per minute or hour than a traditional MIG setup unless you go to multiple wire feeders.
This is just a very short summary. For more read a good welding book. There is a lot to this.
If that's all your welding store supplies, then you need a different welding supply vendor. No matter what process you use; gas, stick, tig, mig, you need to match the filler material alloy to what you are welding. There are a lot of special purpose materials available for doing hard facing, welding difficult materials, and specific weld process requirements.
Again you need to get a good welding handbook and read up on this to get a good understanding.
Notice
