Thirty some years ago I built a logsplitter using a piece of 3X6 rectangular tube for the combination axle/reservoir. It was never large enough, capacity wise, and I put the return too close to the fill pipe/ breather. Consequently, the oil would foam and burp out of the breather. I bought a 6X6 piece of rec tube soon after the mistake manifested itself, but am just now getting around to fabricating a new axle. Do I need a breather in the system? If so, how far from the return line? I have a suction strainer that I bought years ago also. Should this lay horizontally beneath the oil level or vertically? If vertically, I assume it would have to be totally immersed. Any other suggestions would be welcomed and appreciated. The 8 hp Kohler bolts to a plate on the axle assembly and the beam assembly also fastens to the axle. Thanks...
