DP68
- Apr 12, 2013
- Decatur, AL
Question, as briefly as possible...
We are a mechanical piping contractor, and use 6" cut-off wheels with angle grinders more than other other consumable/tool. With that, we have set out to find the best wheel in a all the lands. We have set up a testing station (gravity-fed, no human interference, etc) for phase one of the testing. We have roughly 40 different wheels in the 'competition' thus far, from virtually every mfg I could get my hands you. You name it, were likely testing it.
Well things were running smoothly at first, while cutting our first choice materials to cut- cs pipe. Some wheels did great, some failed terribly, etc...and we were really getting some good data to later crunch to find a good wheel at a good price-per-cut etc...Then....a mystery began.
We switched materials, and found that each wheel...either good or bad...performed exactly the same on each different type of material. It's hard to explain....try this...
Wheel A gets 10 total cuts (until wheel is used up completely) on:
3/4" Pipe CS SCH80 A106
Same wheel then gets exactly the same amount of cuts on:
1" Round Rod CS 1018 CR
1" Round Rod SS304
1" X 4" HHBolt GR8
HOW is this possible? With such wide ranges of the specs for each above, how does one cut-off wheel perform equally on all?? The Grade 8 bolt, for example....one would think would eat up a wheel much quicker than the cs round rod. Nope-same.
We decided to test this further....using a wheel that did a little better in the first round, 25 cuts on the pipe. Well, low and behold, it got EXACTLY 25 cuts on the other materials as well.
So.....can someone explain to us why this is? The only theory we have is that the abrasive blade is turning so fast, so hot, and with so much aggression, that it "over-rides" any work hardening rates or material composition in the metals...??
1" Round Rod SS304
1" X 4" HHBolt GR8
