awake
Titanium
- Jan 24, 2006
- Angier, North Carolina
For those who want the condensed version, here are the questions: 1) Should I repair or replace the Comet ZWD 4030G pump on my pressure washer, or should I replace the whole pressure washer? 2) If repair is practical, what are the most likely components that need to be replaced, and/or what should I be looking for as I tear it down and reassemble?
Here are the details: I did some searching on the forum, thinking I had seen this discussed, but couldn't find anything relevant. I have a pressure washer that has given good service over many years, but now the pump is not working. I thought Ihad seen some "general wisdom" that it wasn't worth repairing or replacing the pump. But as I have priced new pressure washers, I have discovered that this one is at the higher end of non-commercial units -- its specs are 3000psi at 4gpm. The 3000psi is commonly available even under $500, but the 4gpm pushes the price up to the $1000 range.
The pump is a Comet ZWD 4030G. A replacement pump will cost $350 or so. I have a complete parts schematic, and repair kits for the valves, seals, and pistons are available (around $50 for each of those kits) -- if I only needed to service one of those components, I could possibly get this working again for $50. The problem is, I've never been into one of these before, so I'm hoping someone here can give me some pointers on whether it is worth attempting a repair, what the most likely problem points are, etc.
