Cutting NPT on a lathe
Results 1 to 10 of 10
    Dec 2011
    Dearborn, MI
    18
    10
    6
    Default Cutting NPT on a lathe
    Is is possible to cut a 2" pipe thread with a manual lathe with taper attachment? This particular thread it on a casting and the thread needs to end tight into a shoulder. Cant get close enough with a die.
    Jul 2004
    Houston, TX USA
    27,464
    Yes - set the T/A to 3/4" per foot on dia.
    Dec 2011
    Dearborn, MI
    18
    10
    6
    60deg single point tool still set up as if cutting a straight thread? 90deg to axis of work and 30deg on compound?
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    926
    Those NPT threads aren't on all lathes, so good luck.
    Seems to be 11 1/2 tpi.
    National Standard Taper Pipe Threads Size NPT Chart - Engineers Edge
    Jan 2009
    S FL
    880
    239
    209
    A taper attachment is the only easy way on a lathe that i can think of. moving the tailstock over might work but the threading tool needs to be square to the shalf of pipe, not the taper where the threads are cut . if that makes any sense.
    18,897
    7561
    5972
    Quote Originally Posted by IronSkull View Post
    Have a care you don't get TOO close to the shoulder, else the NPT won't be able to reliably seal with the less-than perfectly repeatable fittings that may be offered to mate to it.
    You cannot/dare not turn an NPT die bass-ackwards as you might a straight thread to a shoulder, but NPT dies are common enough that you might also give some thought to grinding one 'just enough' thinner to serve to chase threads made by an unmodified one and pick up a bit extra towards the shoulder, as it won't need the long-lead-in when tracking a precut thread.
    Bill
  7. Likes IronSkull liked this post
    Dec 2011
    Dearborn, MI
    18
    10
    6
    I have a big axleson lathe that will do 11 1/2 per in. And I understand the set up. Just like cutting straight thread, set the tool 90 to the work, and the cut follows 3/4 over a foot taper. Thats all I needed to know. Thanks
  9. #8
    Jul 2004
    Houston, TX USA
    27,464
    Actually if you are just talking one side, the cut follows 3/8" in a foot, because the 3/4" per foot is on diameter.
  10. #9
    Jan 2007
    Norfolk, UK
    17,031
    12681
    12207
    Yes - only set the compound to 29deg, IME it gives a better finish on threads.
    If I was working up close to a shoulder or other obstruction I'd reverse the spindle, invert the tool and cut away from danger
    It works for me on a TA.
    FWIW - If it needs to seal ''right'' as in not overun and foul the shoulder etc etc, either get a gauge (warning big $$) or a sample of what has to screw on to it.
  11. #10
    Feb 2008
    Glade BC, Canada
    632
    587
    122
    No prob. do it all the time. Presume you have 11 1/2 tpi on your qcgb. Hope you have a telescoping type taper attachment otherwise you will be feeding thread depth with the compound. Make sure you snug up the gibs, the backlash in the cross slide screw will allow the pressure on the tool to push the cross slide back that amount. Other than that, a piece of cake. Peter
