Results 1 to 10 of 10
Thread: Cutting Oil
    labman is offline Aluminum
    Nov 2007
    93
    Default Cutting Oil
    For 30 years I have always used Mobilmet Gamma or Omega. Now they only have Mobilmet 766. I do not like it. It has a horrible smell, not as dark, will not drain off the parts. Part of the anti-misting agent I think. It also has a "Best if used before date" of only 1 year?? I never had the old stuff go bad. What could go wrong with it??
    Does anyone have suggestion for a good all around heavy duty cutting oil that is not water soluble?
    SND
    SND is offline Diamond
    Jan 2003
    Canada
    8,367
    I like cooltool II. Some swear by Moly-dee, so I bought 2 bottles, haven't quite figured out what the big deal is yet unless the formula changed at some point, I still get better life and easier tapping with the cooltool II, and it doesn't smell as bad.
    F Spicker is offline Plastic
    May 2011
    cincinnati ohio
    42
    We used to use the omega and changed to G&G Sulfat 32 we source it thru our local BP dictributor.
    Abom79's Avatar
    Abom79 is online now Stainless
    Feb 2011
    Pensacola, FL
    1,130
    We've been using Lubriplate No. 405 Cutting Oil at work. It seems to be good stuff, and its just like the good ole regular dark cutting oil. Not sure whats in it because the jugs dont say, but it works good. We buy it by the gallon jugs.
    AIR-O-LATOR's Avatar
    AIR-O-LATOR is offline Aluminum
    Aug 2007
    Kansas City Missouri
    64
    I too am nearing the end of my Gamma supply and just last week noticed it has been dropped. Was about to try the 766 not so sure now
    Limy Sami is offline Diamond
    Jan 2007
    Norfolk, UK
    9,221
    I'm on a Texaco neat, sorry can't tell you the number etc (the 5gall can's labels has long gone) - I know it was made for ''aerospace materials'' good stuff does all I ask and doesn't stink the place out.
    A friend uses it in a Star JN16 slider and likes it.
    JRIowa's Avatar
    JRIowa is online now Diamond
    May 2003
    Marshalltown, Iowa, USA
    5,715
    You guys can thank the EPA for all of this. Most of the highly sulferized cutting oils were chlorinated to maintain the stability. What is out there now, probably won't be there in a couple of years. I laid in my supply about a year ago. IIRC, there was even quite a discussion here about it.
    There are several companies out there still making the sulferized cutting oils.
    JR
    FredC is offline Cast Iron
    Oct 2010
    Dewees Texas
    377
    If you are using the 766 for spot drilling and tapping MolyDee may work even better, if you are using it in a screw machine you probably can not afford it.
    We are using MobilMet Nu. It is non staining (will not interfer with plating of brass) can be used for heavier machining than the Onnicron we used before. I am not sure what the new designation for Nu is. We still have half of a drum we purchased about 6 years ago. After we got the chip wringer we do not go through anywhere near as much oil as we before.
    JRIowa's Avatar
    May 2003
    5,715
    Mobilmet Nu is another oil that's gone.
    Mobilmet 420 series is the "light" duty. 760 series is the "severe" duty. Both are non-chlorinated.
    JR
    sfriedberg is offline Stainless
    Oct 2010
    Oregon, USA
    1,630
    I'm using Mobilmet 426 neat as low-pressure flood and it's been working well for me on a lathe and a mill with 2HP spindles. Good finishes, no yellow metal staining, no varnish, doesn't smoke. Mostly mild and medium carbon steels, with occasional aluminum or brass. I do some knurling and it holds up for that, too. Somewhere I got the impression that 424 or 426 was the Omicron replacement.
    I also use it on a larger 7.5HP manual mill and that's probably pushing it, although I haven't burned it up yet.
    I don't have experience with the Mobilmet 700 series.
    For hand/spot application and the drill press, I usually use CoolTool II. I like it, but it does smoke when hot and some people really dislike the odor. (Odor is fine by me.)
