cutting speed info
Results 1 to 3 of 3
    Feb 2018
    Indiana
    29
    Default cutting speed info
    What type of cutter is the large facing tool pictured? What speed should it be run at? Its 2-1/4" in diameter. Can these be sharpened? its not in the best condition.
    What speed should the saw cutter be run at? It's 3" x 1/8"
    Is there a formula that can be applied to calculate these speeds depending the material I'm cutting. I'm usually working in mild steel and aluminium.
    Thanks.
    Attached Thumbnails Attached Thumbnails cutter.jpg   saw-cutter-1.jpg   saw-cutter-2.jpg
    Dec 2008
    New York
    8,386
    2241
    Quote Originally Posted by Mattyboy View Post
    Thanks.
    most catalogs selling the tooling will have formulas and recommendations.
    in your head 75 sfpm thats 12/3.14 or 4 so thats 300 rpm per inch
    so 2" dia thats 150 rpm
    3" thats 100 rpm
    for 1018 steel
    obviously cutter vibration might require going slower. most machinist can do basic formulas in their head in less than 10 seconds. if steel and making blue chips your going too fast
    Oct 2014
    Ohio
    86
    347
    16
    This is basic machining. Did you search the forums?
    First one is a shell mill, my guess is HSS. They can be resharpened. I'd run it at about 75-125 SFM in mild steel. Check Machinery's Handbook for better recommendations based on your material's actual composition and hardness. The handbook says 165 SFM for HSS milling (end milling) in cast & wrought aluminum.
    Slitting cutters are more of a black art. Machinery's Handbook says start at 1600 SFM for slitting aluminum with HSS, 265 SFM for slitting mild steel.
    N.B.: RPM = SFM ÷ diameter ÷ .2618, or RPM = SFM × 3.82 ÷ diameter
  4. Likes muckalee liked this post
