I need to put a taper on the end of a shaft. The taper is .0015" for a distance of 1/2" so I would need to set the compound to .0859 degrees. How do I set my compound for such a small angle????
This was fair common on farm equipment, one-lung IC engines etc, but at about 3/4" to 1" run, and a good deal steeper. Mostly, we filed the shoulder back a tad, then cleaned them up, checked with filthy black grease, which was always handy, whether anyone was wealthy enough to own a tiny tube of Prussian blue or no.
IOW - it is done with a measure of "patience", a large ration of "give-a-damn", and whatever sort of "metrology" one can commandeer, if even as simple as grease, lipstick, high-spot.
Check, wipe, try again, repeat.
Not much required in the way of lathes and stuff.
You are down into the zone where the part with the bore in it very well WILL move into accommodation. Just don't ask it to do staircase steps or too
much of it. When it fits well enough to "stick", sits true, sits tight, it IS right.
