jmv_colorado
- Jan 24, 2017
I’ve been using Practical Machinist for a while now lurking and searching for info. Great info! I’ve been in the market for a drill press and have been doing tons of research, and quite honestly, there’s not that much out there about higher end modern drill presses. Seems like it’s either low-end stuff like JET or HF, or vintage presses that guys are fixing up.
Anyway, I had purchased a JET JDP-20MF that I ended up returning (thankfully purchased through my local Home Depot). The table grind was terrible and had some damage. JET sent me a replacement table that was missing the angle gauge and had an off-center drilled mounting hole that made it useless. I decided to return it before they sent me a third table. The chuck wasn’t smooth and needed the key to turn it even with no drill mounted. And the pulley RPM chart stuck to the machine was incorrect (JET offered to send the correct one, but it would take 2 months). The redeeming fact was that it did indeed have very little runout, but I couldn’t get over the other quality issues.
Long story short, I ended settling between Dake and Ellis. The Ellis 9400 looks like a great drill press. I couldn’t find much on it, but what little I could find was positive. It is Trick-Tools best-selling drill press apparently and they talk it up highly, despite not having any info on why it’s better than anything else. Several online shops also incorrectly list the Ellis as being Made in America. It is not. I called Ellis Mfg. directly and they confirmed that ALL parts, including their castings, motor, VFD, etc. are all from overseas (the castings and motor are from China). The parts are shipped and assembled here in the US.
The same goes for Dake with their drill presses. Except their parts and castings come from Taiwan and their VFD is actually made in the US. They assemble, wire, and test their presses at their factory in Grand Haven, MI. I talked to a tech from Dake for quite a while about the differences between their SB-32V, SB-250V and the Ellis 9400. Here’s a run down:
Anyway, I thought that might be helpful for anyone researching new drill presses. In case you’re curious, I ended up with the Dake 32V, if nothing else because it was over $600 less expensive than the Ellis, and for general purpose use, I could use the wider RPM range more than the power down feed. I will update this post with photos and a review of the Dake once I get it and have a chance to use it.
- All three use a 2HP 120V motor with VFD
- The Dake 250V is their answer to the Ellis 9400, and it has VERY similar features, including the Hi/Lo external pulley lever
- The Dake 250V has a slightly higher max RPM than Ellis (1380 vs 1200)
- The Dake 32V has a standard pulley system but with VFD. This gives a much wider range of 46-3473 RPM and you can stay in one pulley setup and adjust the speed up and down with the VFD.
- The VFD that Dake uses on the 32V and 250V is US-made and has less parasitic loss than the Ellis. Dake estimates that while they use a 2HP motor, only about 1.5HP is effectively output by the motor. Ellis’ Mitsubishi VFD has higher parasitic loss and only manages about 1HP actual output from the 2HP motor.
- The Dake 32V is MT4, whereas the 250V and the Ellis are MT3
- The Ellis and Dake 250V have power down feed, whereas the Dake 32V is manual
- The Dake tech told me their drill presses have a max tolerance runout of 0.001" and he also told me that in the last year they had 0 warranty issues for mechanical or breakage. The most common issue is electrical problems related to people plugging the machines into the wrong voltage circuit in their shop. Doh!
- Dake told me they stock all parts here in the US, including for vintage machines, and that if you ever needed something and they didn’t have it, they would pull off of a sub-assembly or another machine to get you up and running ASAP.
- FWIW, the Ellis rep that I talked to was less than helpful and couldn’t wait to get off the phone with me. All he managed to say was that the parts are made overseas, but that they haven’t had any big issues with the machine in 8 years.
- The Ellis drill press does NOT come with a chuck, so factor in that extra $170 into your budget.
