Damaged Gear - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
Thread: Damaged Gear
  1. #21
    Mar 2007
    England UK
    1,515
    613
    578
    I would turn a shallow tapered mandrel and blue it up. Gently push the part up the taper (keeping it square to the shaft) until it sticks then measure the OD where the marks in the blue stop.
    If it still worked when it was worn tri-lobed that should be plenty good enough. The wear is what probably caused the broken teeth IMO.
