looked in MSC, and other places, and found not much if anything other than very expensive live centers with interchangeable points.
Actually could use and might prefer solid center as opposed to a live center, as it is for low speed like grinding and also guiding of small taps/reamers with "point centers" instead of holes.
No solid centers female to be had in MT2 anywhere I looked.
Only interchangeable point live centers, and I was not sure that they all had female centers.
I even tried drilling an old center, but even after grinding a substantial flat on it, the only thing that would touch the material was a carbide spade bit, and Even that was unhappy doing it. The material must have been either case hardened quite deep, or else was HSS.
Probably wouldn't have turned out as-desired anyway, as the spindle is MT3, and I had to use an adapter.
Anyone know where to get them?
I have tiny ones for the watch lathe, no help for the MT2.
