We're looking at needing a bunch (10k) of aluminum cylinders with one end closed. The current low volume design is 3.5" OD, .125" wall, 11" long aluminum tubing, with a 3.375" OD, .125" thick cap inset and glued or welded in. With the higher volume, I'm wondering if deep drawing might be a good process for this. The details of the closed end don't matter too much, there can be a decent radius on the corner.
