After reading many of the posts on this forum regarding compressors, I feel ready to pull the trigger and get a used compressor for my shop.
I am restoring a 1952 Pontiac. Most of the compressor use that I will have, is for a bead blasting cabinet and a DA sander. The rest of the air tools use relatively few CFM's.
I will be able to get by with an industrial 5HP. It will meet my needs with my hobby, with the cabinet needing 15 to 20 CFM, being the hungriest tool.
This being said ... I have been looking for a unit for about three weeks now. I don't want to get a new unit with a Chinese pump. Locally (New-Brunswick, Canada), the new makes are DevAir, Champion and Omega, with Quincy being 120 miles away. All of the new units are around the $2000 mark. I believe that all the pumps on these units are Chinese.
My budget was originally around $1200 for a used compressor.
The best option that I have found so far is this:
The pump is a Kellogg 452TV from the 80's I think, which has a rating of 7.5 (590 RPM) to 10 HP (846 RPM), that has been rebuilt. It sits on a horizontal 80 gallon tank which replaced to original one that was bad. It has a three phase motor and starter. The local compressor shop will exchange the motor and starter with a single phase 7.5HP Leeson, and sell me the unit for $1500 plus taxes.
My questions are:
Can this pump be run with a 5HP motor at around 400 RPM? From the information that I have gathered, It would seem that the pump has ring lubrication. Will running the pump at 400 RPM cause oiling problems? The main reason that I am exploring this option is because the unit will be inside my 16 x 24 foot shop, and I want to make it as quiet as reasonably possible.
If this is a workable scenario, then the 5HP motor will bring this unit down to $1250 plus taxes, which is right on budget for me, while giving me the CFM count that I need.
A second option would be to get the 7.5 Leeson at $1500 and put the compressor outside in a lean-to. It gets very cold around my neck of the woods, but this option would make the inside of my shop very quiet.
I am retired and the project is a hobby for me. I don't really have to make the compressor start on the coldest days ... I could take a break ...
I have read the comments on outside compressors and I am on the fence about this option ...
your thoughts are greatly appreciated ... thank you.
My questions are:
