Differences in UK and US Inch?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 94
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,802
    1157
    474
    Default Differences in UK and US Inch?
    I' justy been reading through some old Popular Mechanics magazines.
    I was surprise to find a reference to different US and UK Inches (PM Feb '63 p58) "...the British gallon is slightly is slightly large than the US version but the inch is slightly smaller there than here."
    I know the Inch as used here in the UK now is defined as 25.4mm, the same as the US inch but, has it ever been different?
    Feb 2006
    Indiana
    11,738
    396
    2968
    Before world or even national standards, there were all sorts of differences from place to place, and not just in the inch.
    Larry
    Oct 2004
    Lancashire, UK
    1,299
    60
    469
    The various inch standards converged on 25.4 mm in 1959 (ever wondered why the conversion is exactly at 25.4000?). The US inch changed slightly more than the British inch, but the differences are very small (millionths of an inch). Having said this it might matter if you were buying slip gauges that were from around this date.
    I think the old inch standards are still in use for some purposes in the US - surveying?
    Feb 2009
    1,802
    1157
    474
    Quote Originally Posted by L Vanice View Post
    Larry
    Yes I realise that I meant differences in national standards, since I would have thought it would have been normal to adopt existing standards.
    Ah! so there was a tiny difference, suggesting difference sources for the national standard inch 'block'
    Aug 2002
    West Unity, Ohio
    22,716
    3165
    6160
    Quote Originally Posted by billmac View Post
    I always wondered what the odds of it comming out to such a nearly "whole" number like that was? Learn sumpin new everyday!
    Think Snow Eh!
    Ox
    Mar 2005
    Somerset, UK
    4,943
    406
    1464
    Differences would have inevitably arisen between the inch standards in different places.
    I don't know when the US Standard inch was adopted, but let's say it was the mid 19th century. There would have been no sophisticated techniques available to compare the length with some invariable property like the wavelength of something, or whatever is used nowadays.
    No, you'd have to transfer measurements from an existing standard, using either an 'end' measurement (i.e. the measured length of a bar). or the length between lines engraved on a bar. In either case, there are limits to the accuracy of transferring these measurements, so inevitably differences would arise, especially with the equipment available at the time.
    Feb 2009
    1,802
    1157
    474
    Sep 2007
    Cairns, Qld, Australia
    2,542
    653
    595
    Theres a good article on Wikipedia: http://en.wikipedia.org/wiki/Foot_(length)
    I'm fairly sure that in electronics drafting software such as Protel Autotrax the inch isn't 25.4mm based on dimensions from US component manufacturers but I can't find the reference article I read this on. It may just be an electronics only dimensional quirk.
    Edit: I found the article here: http://users.tpg.com.au/rcspcb/quotepcb.txt and i include an excerpt from it below, keeping in mind this guy is referring to the 1950's :
    "Many years ago, when I was working at a place in the states that made jet
    aircraft, I was pulled up and questioned about the new emerging 'metric'
    size and the new term was a millimetre. Now this was going to be to the
    masses, Joe Public, an equivalent size known at 2.54mm per tenth of an
    inch.
    Well, I quickly learned that in aviation that measurement is NOT regarded
    as correct; from memory it is 2.5367mm approx. So when you see in future,
    measurements given in millimetres, bear in mind that they are approximate
    'conversions'. Maybe they're near enough for cake making and decorating,
    but not nearly accurate enough in precise engineering terms for serious
    electronic equipment, jet turbines, lasers etc."
    Feb 2009
    Vancouver, B.C. Canada
    1,816
    95
    Quote Originally Posted by SAG 180 View Post
    .....Well, I quickly learned that in aviation that measurement is NOT regarded as correct; from memory it is 2.5367mm approx. So when you see in future, measurements given in millimetres, bear in mind that they are approximate 'conversions'. Maybe they're near enough for cake making and decorating, but not nearly accurate enough in precise engineering terms for serious electronic equipment, jet turbines, lasers etc."
    One inch is defined as 25.4000 millimeters, there is nothing approximate about it.
    Dec 2000
    Bremerton WA USA
    10,606
    40
    3962
    Aviation metics and imperial metric use the same conversion factors as other sectors of science and industry. "2.5367mm" does not equal 1/10" exactly. The offical and legal conversion from millimeter per inch equals 25.4mm per inch exactly. Used to be 39.37 inches per meter. There's about 0.000004" difference but that was changed in the metrification of US Customary Units effective July 1, 1959.
    Units of length, mass, etc are matters of international treaty retified by Congress and implemented by the US Dept of Commerse and similar bodies all over the world.
    Common, local, and customary usage are unoffical and do not contravene the Metric standard and the inch equivalency. These international standards don't affect customary and local units (Danish pounds and French tois for example) used every day.
    There's hardly any other industry fussier over the standards they use than aviation. Nothing is left to chance and their calibration programs are second to none. If the metric standard for aviation was different from other sectors of world commerce and industry, there would be uproar and disorder sufficient for the world standards associations to petition their respective governments for instant resolution in the form of treaty amendments and UN actions in assembly.
    Nope the inch equals eacty 25.4 mm.
  11. Likes Illinoyance, Marty Feldman liked this post
  12. #11
    Jan 2007
    Norfolk, UK
    16,543
    12176
    11608
    According to my calculator
    1000 divided by 25.4 = 39.370078
    39.370078 '' X 25.4 = 999.99998
    MMM?
    That must be the millionths talked about.
  13. #12
    Mar 2009
    Washington
    8,397
    5772
    10130
    Could someone shoot the A hole who invented the inch system. 12 inches to a foot! makes perfect sense!
    Could we also shoot the A holes who resisted converting to metric back in the 70's? Maybe it was the 50's, I can't remember.
    I just don't understand how these ridiculous counting systems caught on.
  14. Likes gkoenig liked this post
  15. #13
    Feb 2009
    1,816
    95
    Quote Originally Posted by John Welden View Post
    .....Could we also shoot the A holes who resisted converting to metric back in the 70's? Maybe it was the 50's, I can't remember.....
    Back in the 1890s or somewhere around then I think, the US did not choose to adopt metric.
  16. #14
    Dec 2005
    Jersey Shore
    3,797
    276
    443
    Samy, you need a better calculator. Then you will be the answer you are SUPPOSED to get.
  17. #15
    Feb 2009
    1,802
    1157
    474
    Dividing and multiplying things by 12 does make sense, if you have limited maths skills (like most of the worlds population for centuries prior to the industrial revolution) e.g. it makes it easy to sub-divide by 2,3,4,6 Similarly 60 is a useful large number.
  18. Likes Rudd liked this post
  19. #16
    Oct 2004
    blackstone. ma
    324
    some people don't like the metric system
  20. #17
    Feb 2009
    1,802
    1157
    474
    Quote Originally Posted by wiz View Post
    How much is that due to their relative comfort with fractions as oppossed to decimals ? (I hope it's not political?)
    Having grown up using metric and decimals, it only recently (while using an imperial thread cutting lathe) that I've fully appreciated how easy it is to use fractional measurements.
    Last edited by Billtodd; 08-02-2009 at 05:48 PM. Reason: must get a spool choaker for IE7
  21. #18
    Jun 2006
    Taylorsville Ky
    3,122
    23
    If everyone in the world used the Metric system and all the machines were Metric it would be fine, but they're not.
    I have Imperial machines so I use the Imperial system. I use .03937 as my conversion number and it works out close enough for me.
    I would prefer the whole world used one system but it don't and someday maybe it will when we have one government and one system for everything.
    I hope I'm gone way before then.
    I think I read somewhere the military was the motivation at or before WWI to standardize sizes and measurements.
  22. #19
    Dec 2000
    Bremerton WA USA
    10,606
    40
    3962
    What's the fuss? I've made metric stuff on Imperial machinery and Imperal stuff on Metric machines by most machining methods and variations thereof - ad nausium. A thread is a thread is a thread and measuring systems can be converted back and forth without end. So long as there are lazy people and calculators the machine intrinsic units can be used to make stuff to any units desired including femto parsec and RPH's.
    It's all stuff and measuring units are all the same providing you got a calculator, a conversion table, slide rule, or logrithm. Done em all; so has everyone else in industry.
    If you favor one unists system over the other fine but why resent the other? Each has advantages, just not the same advantages.
  23. #20
    May 2009
    Mays Landing, New Joisey
    570
    154
    139
    Maybe waaaaay back when the foot/inch/yard thing started people had six fingers and six toes??
